Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Hp 5188 6734
Chipset
Does anyone know where to get the schematic for the dv6550us motherboard?
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
Apr 07, 2013 | HP Pavilion Computers & Internet
CHANGING THE VIDEO CARD ON HP PAVILION TX1000
Nvidia GeForce Go 6150
http://www.ebay.com/itm/HP-TX1000-laptop-motherboard-441097-001-NVIDIA-C51M-GeForce-Go-6150-AMD-DDR2-S1-/160894901951?pt=Motherboards&hash=item2576155ebf
Scroll down to the first larger photo.
(Under the green - Exhibition: )
This is a bottom view of the motherboard. Look to the right of the white Socket S1 processor socket.
That is an Nvidia NF-G6150-N-A2 chipset,
http://www.ebay.com/itm/nVIDIA-NF-G6150-N-A2-BGA-North-Bridge-Chipset-NEW-/220724258873
Uses a BGA surface mount, to mount it to the motherboard.
Ball Grid Array surface mount.
To explain the BGA surface mount;
The AMD Turion 64 X2, model TL-56 processor for your laptop, uses contact pins on the bottom.
The pins go in the socket holes of the Socket S1 processor socket.
(638 pins, 638 socket holes)
With a BGA surface mount there are no contact pins, nor matching socket holes.
In place of the contact pins are Solder Balls.
In place of the socket holes are Copper Pads on the motherboard.
(They are gold plated)
The chipset is set onto the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a SPECIFIC temperature, and LENGTH of time.
The heat melts the Solder Balls, and solders the chipset TO the Copper Pads. (Which in turn solders the chipset TO the motherboard)
More information on a BGA surface mounted device, using a BGA Rework Station,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red -
Take a few minutes to view the IR 650 demo video
Also another method used to remove, or reflow a chipset.
Posted ONLY for reference. Not advertising for this tech, nor website,
http://www.youtube.com/watch?v=JEpnqhRYGLw
(Also check out his;
HP Pavilion dv2000 blank screen fix.....
and, HP Pavilion dv9000 blank screen fix......... )
Note how this tech PLAINLY states;
1) The heat MUST be uniform all around the chipset.
Cannot be any 'cold spots', or 'hot spots'.
2) The temperature MUST be at a specific temperature, and checked all around on the chipset.
3) When using the type of heat source the tech is using, the heat MUST be slowly withdrawn away.
This allows the chipset to cool slowly, and helps prevent cold solder joints.
(Chipset to motherboard)
MHO?
You better be GOOD to do what he is doing.
The best method hands down though, is to have it done with a BGA Rework Station.
http://h10032.www1.hp.com/ctg/Manual/c00853874.pdf
Or,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3185028&
In the list click on -
HP Pavilion tx1000 Entertainment PC - Maintenance and Service Guide
Regards,
joecoolvette
http://h10025.www1.hp.com/ewfrf/wc/product?product=3185028&lc=en&cc=us&dlc=en&lang=en&cc=us
Oct 21, 2012 | HP Pavilion TX1000Z 12.1" Touch-Screen...
Hp G62 notebook PCI Simple Communication driver
Good Morning.
Please install the chipset driver on the Laptop, this will fix the issue.
Here is the weblink to download the latest chipset for your laptop.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=4186863
Select the Operating system and download the chipset drivers and install it.
This will fix the issue.
Jul 06, 2011 | HP G62144DX Laptop
Cant find a workable coprocessor, ethernet controller and sm bus controller driver for my hp dv6000 laptop on hp's site.
do you use Vista 64 OS, if yes, then try this.
coprocessor + sm bus controller + ethernet = chipset driver
Nvidia chipset driver
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36079.exe
they all r included in chipset driver, if your NB has AMD processor
plz confirm if it works
May 06, 2011 | HP Computers & Internet
The laptop is a dv6700 HP Pavillion. What steps should I take to solve this issue.
About it being an HP Pavilion dv6700 laptop?
Ehhh, giveittome. I will use it.
Looks like I'm going to have to guess since the 'Issue' wasn't stated.
The main problem with the Pavilion dv6700, which is part of the Pavilion dv6000 series of Notebook PC's, is that all the indicator lights come up, but there are no graphics being shown on the LCD screen.
The screen is black.
This is due to a graphics chipset problem, caused by a poor cooling design of HP designers.
The graphics chipset (GPU. Graphics Processing Unit), is mounted to the motherboard in a BGA surface mount.
Instead of pins coming off of the bottom of the chipset, as on the older Processors, there are Solder Balls.
The motherboard has tiny copper pads that line up to the solder balls.
The graphics chipset is set into place, then heat is used to melt the solder balls, and attach the graphics chipset to the motherboard.
Due to the poor cooling design, the graphics chipset overheats, and the solder connections are partially melted.
The graphics chip now has a poor contact to the motherboard.
This video shows you what's going on, and how to solve the problem,
http://www.youtube.com/watch?v=bnkQNmKauEc
This is the download page from HP Support, for the Service Manual (free) for the HP Pavilion dv6700 model series of Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3650965&
On this page click on the file name in blue>
HP Pavilion dv6500, dv6600, and dv6700 Entertainment PCs - Maintenance and Service Guide
This is a PDF file. Allow up to 30 seconds to see the first page, and additional time may be needed to full download.
Regards,
joecoolvette
Dec 08, 2010 | HP Computers & Internet
Hp dc 7700 SFF, board is 965 chipset & i want 64-BIT processor
Yes, it the Intel 965 Express chipset will support processors that are based on the 64-bit technology.
This is to include the;
1) Intel G965 Expresschipset
2) Intel P965 Express chipset
3) Intel Q965 express chipset
Supporting Data;
1) Intel Support, and the main support page for the Intel 965 Express series of chipsets,
http://www.intel.com/support/chipsets/sb/CS-022768.htm
In the top list given, you can click on -
Associated Intel Processors,
to see if the processor you have is compatible.
2) This is a List of Intel Chipsets, on Wikipedia,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_Chipsets
I have linked the page so that it comes up directly on the Core 2 chipsets.
Here looking down the left column, you will see the G965, P965, and Q965 Express chipset's listed.
You can scroll across to the right for each chipset listed, and see what processor types the chipset supports.
There isn't an Intel Core 2 processor made, that isn't a 64-bit processor.
This is a List of Intel Core 2 processors,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors
Feb 13, 2010 | Computers & Internet
COMPAQ presario AUDIO?
For Intel chipset,here is the link for windows XP
ftp://ftp.hp.com/pub/softpaq/sp28501-29000/sp28552.exe
For AMD chipset with NVIDIA chipset,here is the link for windows XP
ftp://ftp.hp.com/pub/softpaq/sp27001-27500/sp27325.exe
For AMD chipset without NVIDIA chipset, here is the link for windows XP
ftp://ftp.hp.com/pub/softpaq/sp25501-26000/sp25795.exe
Dec 26, 2009 | Compaq Presario R3000 Notebook
COMPAQ presario no audio?
I cant play a movie full screen on my hp laptop.. it goes black and grey everytime. what should i do =[
I think you need to update the graphics driver. It might be downloadable from the laptop or chipset manufacturer's support website. For example, if your chipset is made by intel, please go to intel.com/support/chipsets then select the chipset family. Choose the specific chipset then click on "download" under graphics. After this, please select the operating system...hope this helps.Please let me know. Thank you.
Sep 30, 2008 | HP Computers & Internet
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
