All Sc errror code list in konica minotal 7272 copier and thier solution
2 Suggested Answers
  • 60 Answers
SOURCE: i have a konica 7272
1. Access the 25 mode 2. Press ...................................1: Software SW setting 3. Press the left up-arrow, which is displayed on the touchscreen, twice. The number displayed above the up-arrow will change to 03. 4. Select the bit number of switch 1, using the right up-arrow. 03-1 will be displayed. 5. Press the OFF key, displayed on the touchscreen. 7. Power the machine OFF/ON
Note:If you are not a technician, better call one.....
Posted on Feb 19, 2011
Konica minolta 7272 error codes sc50-5 & 29-4 ....... what can I do......... any solution plz
Mam/Sir,
SC 50-5 is that main drive motor can not turn properly, the second code is that you drum sensor is not reading the drum, For both codes you will need a tech that has some legacy Konica experience might need a a new drum when was last time developer was installed? Might need a new motor or worse case a main control board. Both codes require removal of the drum/developer assembly. Sensor for the drum is under the drum and requires drum removal. Will also need a new cleaning blade which might be the reason the drum can not turn. Developer for the developer section. Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 14, 2016 | Konica Minolta Office Equipment & Supplies
KONICA 7272 CODE SC49-01
Image processing board failure. I would first check all the connection on the image processing board pull each connector one at the time and check for a bent pin, worse case the image processing board is bad, doubt you can find one a Legacy Konica Machine Konica is now KonicaMinolta.
Jan 21, 2015 | Konica Office Equipment & Supplies
7272 konica minolta
no 18-60 in the service manual please chk again
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Code sc29-03 in konica minolta 7272
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Konica Printer Support
Dec 20, 2013 | Konica Minolta Office Equipment & Supplies
CODE 02-01 SC23-04
Sir/Mam, please check the model and the code looking at service manual for the Konica Series 7255 not such code per what model you currently have this problem with
Feb 08, 2013 | Konica Minolta TN601K Toner for 7155,...
CODE 02-01 SC23-04
PCL connection area. Mite want to check all connections to the print control board. And Memory sticks, also have the firmware re-flashed.
Sc 21-05 for konica minolta 7272
The transfer and separation corona cleaning system locks, lubricate or replace corona unit
Jan 11, 2013 | Konica Minolta Bizhub 7272 Image Control...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
I have a konica 7272 ... when i switch it on, i get this report code SC 34-01
Dec 22, 2010 | Konica 7410 Laser Printer
18 people viewed this question
k24674
