Question about Toro Garden
How to lube deck spindles on 8 h.p. toro 8/32 rear engine mower
  • 76 Answers
SOURCE: white smoke coming out of carb.
you are either running to rich or your timing is off and your valves are opening before your spark hits you may have bent valves also and they are not seating properly you should be able to check this and change your valves if need be you have to seat them just like a car if you need more help let me know i can walk you through this but i will need motor h.p. and model and serial #s on the motor
Posted on Jun 29, 2009
wadembly
  • 513 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
  • 127 Answers
SOURCE: Toro mower will not start
coil is breaking down under heat
Posted on Jul 26, 2009
  • 72 Answers
SOURCE: Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Posted on Aug 04, 2009
  • 138 Answers
SOURCE: remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Posted on Aug 22, 2009
Toro 52" need a spindle shaft for the deck,part no.78-6710 hard to find & very expensive,maybe there is some used ones around the countryside in Oz on a retired mower deck?
there is three on ebay by your part number. Toro Wheel Horse Mower Spindle Shaft 78 6710 $54 is about average for this type of repair. But if yours is straight and just wore at the bearing area you can JB Weld it back to size .
May 14, 2016 | Toro Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
How to fit the mower deck belt on a ***** LT130?
The best way is to remove the deck from the mower. At this time you should grease the pulleys and spindles. there are four post that hold it. two on either side and one in the front. they are held by cotter pins. lower your deck level down makes it easier. you will have one engagement cable that just pops out it has a spring on it. then slide it out from the easiest side or pick the mower up and pull deck out . at this point it will be apparent where the belt goes and do your your other maintenance of cleaning and lube. factory says lube spindles every 8 hours of use.Then put it back under and re attach.
Sep 15, 2014 | Husqvarna Lth 130 Riding Mower Illustrated...
One side of mower wont turn
Your spindle may be seized. try turning the side by hand. Try moving it back and forth. If there is movement then your bearing in your spindle is bad. I f no movement than check under your deck to make sure nothing is stuck holding the blade from turning. You will probably have to replace your belt as well
Aug 06, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Mower blades speed slows down in thick grass, the engine speed remains constant 217D
Hi, check that the belt is not worn and bottoming out in any of the pulleys and also check that none of the deck spindles are stiff to turn with the belt removed. Regards Phil.
Jul 03, 2012 | Toro Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower leaves uncut strips between blades.
measure blades on a level surface.place each blade side to side and see if their is a difference,all measurements should be the same,if not you have a bent deck or a spindle that is bent.
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
12 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
