Question about Goulds Pumps Goulds 2AB2 - AquaBoost II Controller
The controler not have green light on
The volts is 220 but the controller not working
    New Friend:
The voltaje is correct in controller 2ab2 but not light green on
Posted on Jun 07, 2014
Have a 115v swamp cooler pump with two black wires and ground coming out of it. Needs to be wired to controller. How do I tell which of two terminals in controller to connect black wires to?
check to see if 220 volts between two black wires if so need 220 volt controller first black line 1 second black line 2 green ground
Jun 24, 2017 | Pool & Spa
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Burners nor oven works although control panel lights up
first thing I would check is the voltage going to the unit. If the voltage is right at the plug, I would check where the power cord connects to the unit. If the controls are touch controls and not knobs, very possible there is a control panel or control board issue. I would check electrical supply first. Got to have at least 220 volts. anything over 220 is ok. anything under 208, not good.
Nov 27, 2015 | Frigidaire Kitchen Ranges
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
I have a Frigidaire stove model number fef364dwa everything works on control panel. all surface lights work,clock works oven controls work, only the eyes don't get hot and oven doesn't get hot. do you have...
your stove is 220 volts,the lights, clock and controls, they work on 110 volts, and when there is a short on the 220 part of the stove, the elements work on 110 volts.that's the reason they only get warm. there is a short in your stove.
Dec 09, 2008 | Kitchen Ranges
Goulds Pumps Goulds 2AB2 - AquaBoost II Controller Logo
81 people viewed this question
Top Goulds Pumps Plumbing Experts
Steve
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
