Question about Acer Aspire Computers & Internet
Acer aspire x3470
How replace the cmos battery
SOURCE: acer aspire 5720 bios password reset
Posted on Dec 02, 2008
  • 13433 Answers
SOURCE: where is the CMOS battery located on Acer Aspire
Bottom of the laptop, the big cover that comes off. Below the wlan card
Posted on Feb 18, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
Posted on Oct 11, 2009
Testimonial: "Thank You"
nblady
  • 206 Answers
SOURCE: Replacing CMOS battery - Acer aspire 3000
Before you begin, back up your data and remove the battery. CMOS Bios will be lost but will reset on restart.
    Instructions
  1. Step 1 Open the laptop computer's screen and lay it back as far as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  2. Step 2 Press a flathead screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  3. Step 3 Pry up the other side of the bar with the flathead screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  4. Step 4 Remove the two Phillips screws securing the computer's keyboard. Then, slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  5. Step 5 Remove the four screws securing the cover plate over the motherboard and remove it as well.
  6. Step 6 Locate the CMOS battery at the bottom right corner of the motherboard.
  7. Step 7 Remove the battery by prying it up gently with the flathead screwdriver. Then, replace the battery with a new one of the exact same specifications.
  8. Step 8 Replace all the parts in the laptop in the reverse order that you removed them. -Battery Replacement
User Manual
Good Luck
Posted on Feb 15, 2010
Slasher_X
  • 767 Answers
SOURCE: where is the cmos battery on an acer aspire 8920
Before you start
1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
2) Purchase the battery through Acer or a local or online computer parts dealer.
3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices.
4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal of the CMOS battery
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery.
The battery should look something like this
slasher_x_0.jpg Plugging the new battery in
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Posted on Nov 12, 2010
Does this P.C have an internal battery, and if so can it be changed
If you mean a BIOS or Backup cell, yes, akk OC's have. We cannot comment on how to do it as you don't reveal the make and model.
Aug 06, 2015 | Computers & Internet
Tip
How to replace the CMOS battery in an Acer Aspire laptop.
General info
All laptops have a CMOS battery. The main purpose for the CMOS battery is to store the system time, date and BIOS settings even if the computer is turned off or the main battery dies. Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.
Before you start
Finalizing
Please rate this tip by clicking the thumbs up at the bottom right of this solution. Your rating is much appreciated.
<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman
on Nov 12, 2010 | Computers & Internet
Is the cmos battery soldered to the motherboard on Acer Aspire 5336-2524
no, cmos batteries are not soldered to the motherboard nowadays
Jun 28, 2015 | Acer Computers & Internet
How to replace cmos battery of acer aspire 5735?
You can find the Service Guide for download at the following llink
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
hopefully this should help you out. It is typically on the motherboard as a silver watch type battery. Also look up
acer aspire 5735 CMOS on you tube
May 26, 2015 | Acer Computers & Internet
How do you replace the cmos battery in an acer aspire #7110-2069?
you will have to open your laptop up todo this,then you will see your cmos battery on the board.
May 31, 2014 | Acer Aspire 7110-2069 Notebook
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Also unplug any external hard drives, cameras or other external devices.
Removal
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
Cmos battery acer aspire 9300 Where can i find the battery? Have to replace it.
From ebay. (3$)
http://shop.ebay.com/i.html?_nkw=acer+aspire+9300+cmos+battery&_sacat=0&_stpos=&gbr=1&_dmpt=Laptop_Batteries&_odkw=acer+aspire+9300+battery&_osacat=0&_trksid=p3286.c0.m270.l1313
Jul 28, 2011 | Computers & Internet
Where is the cmos battery on an acer aspire 8920 and how do I change it.
Before you start
Finalizing
Thanks.
Nov 12, 2010 | Acer Aspire 8920-6048 Notebook
Acer aspire 5610z notebook
the cmos battery is a soldered on type, it has a purple plastic ring on it and it is under the pcmcia slot. I have not found a replacement yet.
Sep 25, 2008 | Acer Aspire 5610 Notebook
Computers & Internet Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
