Question about Maytag Washing Machines
Maytag washing machine model LAT9606AAE will not start or drain
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
SOURCE: maytag lat8840baw washing machine.
my maytag lat8840 will not fill with water on any cycle...wants to spin and rinse when I turn it to those points
Posted on Jan 28, 2009
  • 441 Answers
SOURCE: Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Posted on Jul 16, 2009
  • 714 Answers
SOURCE: I have a maytag washing machine model PAV2300AWW
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 17, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Water sloshing over top of washing machine tub.
I have the same problem model lat5006 still no answer
Jul 31, 2010 | Maytag Washing Machines
Why my Maytag model performa, washing machine fill
Check drain hose not too low ...Syphon Effect....Good luck
Sep 29, 2009 | Maytag Performa PAV2200
Washer fills with water, but does not agitate or spin rinse
This could be bad door switch or bad timer. You need to test it with a multimeter
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washing machine releasing water at wrong time
your drain hose is to low ,,make drain hose go up the height of machine berfoe it can come down,,,sphion effect...onthejob
Jan 14, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Dec 18, 2007 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
