Question about Vehicle Parts & Accessories
Where the speed sensor on a 1996 buick century is located
    Top Expert:
  • 3,698 Answers
Comes out of the transmission
Posted on Oct 01, 2014
Where is the vehicle speed sensor located in a 1999 Buick century
Vehicle Speed Sensor Replacement
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels. Remove the right engine splash shield. Refer to Engine Splash Shield Replacement in Body Front End.
Remove the vehicle speed sensor wiring harness connector.
Remove the vehicle speed sensor bolt (9). Remove the vehicle speed sensor (10) from the extension case.
Remove the O-ring (11) from the vehicle speed sensor (10).
Vehicle Speed Sensor (VSS)
Lower right side of the engine compartment, on the transaxle
Sep 05, 2015 | Buick Cars & Trucks
Where is the location of the transmission control solenoid on 1996 Buick Century, help
The solenoids are located inside the body of the transmission.
May 17, 2011 | 1996 Buick Century
2001 buick century input speed sensor location i need to change the input sensor is in side the transmission yes or no
The speed sensor is not really inside the transmission, it is on the outside of it.
Mar 09, 2011 | 2000 Buick Century
Need cam sensor information. service engine light is on.
It depends on which engine is in your Century but typically the cam sensor is located on the side of the motor opposite of the belts. it is located on the top of the engine and is usually held on by two small bolts. Hope this helps!
Jul 30, 2010 | 1996 Buick Century
1996 buick century, I had a tune up and egr valve
Have an auto parts store check for the code. It is possible that you have a bad O2 sensor or your catalytic converter is clogged.
Apr 10, 2010 | 1996 Buick Century
Speedometer wont move and the miles on the car wont show i changed the fuse still same problem (1998 Buick Century)
This could be the speed sensor in the transmission. I believe it is electric on the 98 takes about 15min to change and is located on the long end of the trans.
Aug 02, 2009 | 1998 Buick Century
ABS Light
Bad abs sensor wheel speed sensors are mostly common. However recommend that you take this vehicle to an Auto_zone they will put it on a code scanner for FREE. Then you will know exactly what the problem is with t=your car. Don't guess and if some say its xyz they are only assuming. get it check by a computer. I can provide further help if needed. Remember when ABS light is on abs is INOPERABLE. Its a vital safety feature especially in wet slippery conditions. Good Luck and thanks for using FIX YA
Jan 05, 2009 | 1996 Buick Century
Speed sensor for a 1996 Century
Dave,
May want to see if the parts store gave you a good sensor or not. Also May want to check and see if you have a transmission input and output sensor as well. these will also give you the same symptoms. Whatever it is, the transmission is not sending the speed signal to your ECU which is in turn not sending the right shift points until its too late causing the hard shifting and also since the ECU doesnt have a speed signal you may not get an odometer/speedometer reading (one or both may go out). Hope this gives you some direction. Good luck. Thanks for using fixya.
JC
Dec 29, 2008 | 1996 Buick Regal Olympic Gold
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
