Question about DeLonghi EC702
Water leaks when the coffee button is pressed. does not leak during heating cycle
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: coffee machine is leaking from bottom
the rubber seal for your coffee machine need to be replace.
Posted on Mar 30, 2007
  • 4 Answers
SOURCE: coffee machine leaking hot water also all lights come on front
Buy another one there like 10 bucks...
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: leaking
You need to contact Delonghi and order a part. This is the steam/water outlet assembly. This part includes an electronic solenoid which controls the water and steam output. I have had this problem 3 times. You may find the steam/ water is very loose when you try to wobble it sideways. This is the indication as to what is the problem, (as mentioned above).
Posted on Oct 06, 2011
mc1bean
  • 3053 Answers
SOURCE: water leaking from bottom of
Hello, cat
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
May 13, 2011 | Jura Capresso Capresso IMPRESSA C9 One...
Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
Apr 01, 2008 | Keurig B50 Coffee Maker
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
The coffee is very weak. Have tried several different coffees but the same with all Brands. Have cleaned the top were the water comes out. Have run several cycles of water through it but coffee still is...
Make sure the 'vacation' switch is turned on. In addition to the warmer switch on the front of the unit, there should be another switch located on the side/rear of the coffee maker. If that is turned off, the water won't be pre-heated, and you end up with luke-warm water going through the coffee during the brew cycle. If that is not the problem, then there is an issue with the tank heating element and the unit will have to be repaired.
Dec 12, 2010 | Bunn NHB Coffee Maker
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Oct 21, 2010 | Keurig B50 Coffee Maker
Water leaks out between coffee brew basket and carafe.
If you are noticing the water that is leaking at the base, I was having the same problem. If you can specifically see that the leak is coming from between the basket and carafe - then you may have a different problem. My problem appears to be that the heating element is shot - it leaks when you start the brewing cycle. I found this out by taking off the bottom and raising up the coffee maker and puting it on a mirror to view what was going on. As soon as the brewing starts and the system is under pressure, water starts forming on the metal tubing part of the heating element. I suppose it's possible that water is leaking down from the tubes, but it looks like it is getting forced out of the metal, so there must be small holes, caused by corrosion. I will check further but I can't find a replacement heating element online so I may have to purchase a new coffee maker.
Apr 21, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
My machine is brand new and when I plugged it in for the first time, the light comes on but the water won't heat up.
Press the coffee button to fill the boiler, then run the hot water cycle for about 5 secs. If machine still does not heat then the thermostat needs to be reset.
Oct 04, 2009 | Saeco Starbucks Sirena Espresso Machine
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
How to get the clean off an ge coffee pot?
To clean the coffee stains there has a magic cleaning tools--magic melamine sponge. Magic sponge just need water and don't need detergent , strongcleaning capacity,saving time ,energy,convenient. The most distinguish with the traditional cleaning sponge is that the magic melamine sponge adopts physical cleaning principle. During cleaning, it can automatically absorb the stains on the surface. It is like countless superstrong mini cleaners working together.
When you use the magic melamine sponge to clean the oils on the dish you just need to follow below steps:
Step 1:put the magic melamine sponge into water,
Step 2:then use the hands gently squeeze the excess water in the magic melamine sponge.
Step 3:using the magic eraser gently wipe the part where has the pen stains
Step 4:after cleaning you can use a dry cloth to wipe up the dirts on the walls
Step 5:finally, you just need to put the magic eraser into clean water, the dirty will be dissolve automatically.
En world sales magic eraser sponge En world dedicated cleaning sponge...
Magic Melamine Sponge
Dec 21, 2008 | GE 106591 Coffee Maker
Water leaks during brew cycle
you have a split in or a loose conection where the water pipe conects to the boiler so water comes from there and the lack of pressure is making the machine work harder which makes it sound bad
Dec 14, 2008 | Saeco Vienna De Luxe Espresso Machine
DeLonghi EC702 Logo
97 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
