Question about Dewalt DC011 AM/FM Radio
Stereo radio not working
Battery disconnected while mechanic was fixing my xg 350 now my cd and radio won't work
How can I fix my 6 Disc CD Player?
I would try disconnecting the Negative terminal on your battery for 1 min. This will reset your radio and hopefully recycle the cd mechanism. If that does not work I would take it to a reputable stereo shop.
Sep 15, 2017 | 2006 Kia Amanti
The CD player in my factory stereo has a CD stuck inside of it. We know that the radio is programmed for this VIN # only. Can I unplug the stereo and fix the CD player and then plug it back in without...
Try disconnecting the battery for a few seconds and try to eject the cd, if this don't work you can take the cd player to the dealer ship and they can send it to be repaired
Aug 05, 2011 | 2004 Chevrolet Monte Carlo
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
I am able to select the aux input and tuner input on my stereo but am unable to select the cd input what could be the problem .
Is there a cd inside of the cd mechanism? If there is, you can try resetting the radio. If that doesn't work, try disconnecting the battery for a few minutes.
Jul 20, 2011 | Pioneer Car Audio & Video
2004 hyundai XG-350 Check engine light is on and
Sorry Peter I do not have a solution to your car problem, but I also own a 2004 XG-350 and the SAME EXACT thing is happening to my car right now, crazy huh. Pretty much started out of nowhere...the boyfriend is going to go try the leaving keys in ON position and reconnecting the battery. Did you happen to find out what was wrong with yours, thought maybe if you did it would help save me a step. Praying nothing to serious. Hope you got your car working well again!
Thanks,
Nikki
May 14, 2010 | 2004 Hyundai XG350
I cannot eject the CD from my stereo in my 2003 Mitsubishi Galant.
The radio may need to be reset. Turn the radio off and disconnect the battery for 1 min and then reconnect the battery, this should reset the radio and the CD will come eject. If the CD will still not come out, then there is a mechanical problem with the Radio and your going to have to have it repaired or replaced. Good luck and hope this helps, Note make sure the radio is off before you disconnect the battery so you will not be prompt to enter a activation code.
Nov 11, 2009 | 2003 Mitsubishi Galant
Cd stuck in stereo
i had this prob in my ford truck, i took a long tweezers and helped it out while hitting the eject button didnt have a prob since
Oct 30, 2009 | 2005 Dodge Magnum
How do I remove the alternator from a 2002 V6 Hyundai Sonata once I have disconnected the alternator?
Removal
  1. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
Fig. Exploded view of the alternator-XG 300 and XG 350
Removal & Installation
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator 5ead6d5.gif
  2. Fig. Exploded view of the alternator-XG 300 and XG 350
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Fig. Exploded view of the alternator-XG 350
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
  6. Connect the negative battery cable.
I hope hrlp you with this. Good luck and remember rated this help-
Aug 25, 2009 | Hyundai Sonata Cars & Trucks
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
May 26, 2009 | 2003 Volkswagen Jetta TDI
2002 Hyundai XG 350L Check Engine Light w/o a code
hi the check light has a short could be expensive to fix or not trouble nowadays electronic componts are tempermental so have you got your code for your radio as the soultion to the problem could be as simple as disconnecting your battery for 10 minutes and reconnect this will reset your ecu unit and any abnormall glitchs in the computer trouble is you will lose your codes for the radio this is something that is rare but i have come across before running the car without the check light working only tells you if the emmissions system is working or not the car will run fine as it as a back up system so if the cars not giving you any problems it will be ok but this should work if not then check the wiring from the light and the ecu yates210456
Aug 28, 2008 | 1999 Hyundai Accent
Dewalt DC011 AM/FM Radio Logo
24 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
