Question about Briggs & Stratton 200278gs Water Inlet Kit For Pressure
How to replace briggs & stratton water inlet for pressure washer
  • 1111 Answers
SOURCE: just bought a new Briggs Stratton 6 75 pressure
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
Posted on Jun 20, 2009
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
roadtech7
  • 297 Answers
SOURCE: How do I winterize a
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Posted on Nov 04, 2010
  • 57 Answers
SOURCE: Briggs & Stratton engine on my Craftsman
try changing the spark plug.
Posted on Dec 20, 2010
  • 1267 Answers
SOURCE: The 6.5 hp Briggs & Stratton engine that
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Posted on Jan 03, 2011
Troy built
replace pump or service valves or check inlet for obstruction
Mar 20, 2014 | Briggs & Stratton Power Products 1539...
Will not produce pressurized water
check the pressure regulator valve. It may be set wrong or stuck open. If that is not the problem then a valve may be stuck in the pump.
May 17, 2013 | Briggs & Stratton Briggs Stratton 1800...
I have a Briggs & Stratton Pressure Washer it was just working Fine THEN the water stopped coming out of the wand? Any Suggestion
Remove the tip and pull the wand trigger without the tip in. If water comes out then your tip is clogged. Clean the tip and reinstall. Or try a different tip.
Its also possible that there is a kink in the supply hose to the unit.
Try these first, it should solve the problem about 90% of the time
Jul 02, 2011 | Briggs & Stratton Pressure Washer...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Jan 30, 2010 | Briggs & Stratton Pressure Washer...
I have a briggs & stratton pressure washer that every time I engage the spray hose my pressure washer stops. Why???? I have left it running for a couple mins. before engaging, doesn't seem to help
PROBABLY the valve that admits the water to the pump is sticking. USUALLY bad O-Rings. If the valve sticks closed, the pressure won't build up. If it sticks open, the washer will stall. Most other problems are engine problems due to bad gas, carbureator, etc.
Oct 09, 2009 | Briggs & Stratton Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Briggs & Stratton 200278gs Water Inlet Kit For Pressure Logo
29 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
