Question about Sony RDR-VX560 DVD Recorder/VCR
DVD VCR COMBO DVR DOOR DVW 5000 STUCK CLOSED NO SMALL HOLE UNDER DOOR
4 Suggested Answers
SOURCE: my dvd says open door will not open
You probably need a new dvd belt it is 24.25 mm rectangular. or it could've slipped off. Take off cover and move white wheel with teeth very gently until dvd tray starts to open then you can gently pull on it only pull it half way out and look in center of where dvd would normally be. There you will see the bigger and smaller wheels that control dvd player. look around for the belt. Make sure power is off when you do all this.
Posted on Apr 22, 2009
  • 9 Answers
SOURCE: Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Posted on Jul 22, 2010
muntejaya
  • 10421 Answers
SOURCE: SONY DVD/VCR combo SLV-D950 Hi there, any idea how
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_4r5f
Posted on Feb 27, 2011
How do I get the VCR to play on the tv? It's a Sanyo DVW-7100 DVDPlayer/VCR Combo. The DVD will play but the VCR won't show up on the TV.
This maybe too simplistic but are you sure you have the right command buttons toggled try to set the player to VCR and not dvd.
Set the player to VCR with a tape in it and press play. I hope this works for you
Sep 29, 2010 | Sanyo DVW-5000 DVD Player/VCR
The door of my dvd player will not open. It sound like it wants to, but nothing happens.
This sounds like a problem with the mechanism of your player,it is probably stuck.
What you should do is to open up the player and try to open the door with your hand by pulling it,check to see what is stopping it from opening and clear the object stopping the door from opening automatically
Please note that it might just require oiling the door wheel to make the door open and close automatically.
Aug 20, 2010 | Sanyo DVW-5000 DVD Player/VCR
DVD is stuck in my JVC VCR/DVD Combo
Find the small hole on the front of the player. Get a small paper clip and straighten it out. Insert one end into the hole and the DVD should pop out.
Feb 20, 2009 | JVC HR-XVC19S DVD Player/VCR
Sanyo dvw-1600
The motor for the DVD drive may be busted. I reccomend getting a new DVD/VCR Combo. otherwise, your dvd player is basically fried
Sep 03, 2008 | Sanyo DVW-6100 DVD Player/VCR
Will the dvw-5000 play the dvd-ram disc ?
By looking into your information, I found my answer. " What disc will it play".
Aug 07, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Aug 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
How to Hook Up Sanyo DVW 5000
TRY A DIFFERENT TYPE OF VIDEO OUTPUTS LIKE S-VIDEO, OR COXIAL
Jul 21, 2008 | Sanyo DVW-5000 DVD Player/VCR
DVD player problem
I had the same problem before.  I found a loose rubber ring which drives the door open/close may be the cause.  Use honey wax or candle wax to wax the ring will be most likely to solve the problem.  The only thing is you need open the box by yourself.
Jun 24, 2008 | Sanyo DVW-5000 DVD Player/VCR
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Sony RDR-VX560 DVD Recorder/VCR Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
