Question about JVC AV-36260 TV
TV turns on, then immediately off again
Whether I use the remote or the button on the TV itself, it is only on for less then a second before switching itself back off again. The only troubleshooting suggestion in the owners manual that applied said to unplug it for an hour and try again. I left it unplugged for a day and tried, but still didn't work. I see another problem on here that might be the same, but the reply was way to technical for me. Can anyone offer any help, or should I just go get a new TV? my jvc tv power on and off. its just a second when i open the tv using button or remote its suddenly off and on again always on and off. how to fix this problem?
    Problem Solver:
  • 19 Answers
Re: TV turns on, then immediately off again
Its the technical problem, the switch it my be hold in or[stuck]or try to see experts near you.
Posted on Nov 02, 2007
0 characters
3 Points
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Standard (CRT) Televisions
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Standard (CRT) Televisions
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Standard (CRT) Televisions
No power
your on off switch button need to replace or try to spray contact cleaner then press on and off a few time and pls unplug the power cable first ok
Mar 24, 2009 | Standard (CRT) Televisions
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
The flyback transformer are damaged.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Shut down when press
1.Check whether your Remote buttons jammed else on the TV.
2.there might be some problem Remote ir receiver unit in your TV
3. Microprocessor/microcontroller unit on Remote signal receiver board
Dec 28, 2006 | Philips 32PT6441/37 32" TV
JVC AV-36260 TV Logo
90 people viewed this question
Top JVC Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a JVC Standard (CRT) Television Expert? Answer questions, earn points and help others
