Question about Xerox Phaser 3600DN Laser Printer
Squeak xerox 3600 - Xerox Phaser 3600DN Laser Printer
How can i fix this message LSU motor error cycle power
That error is caused by a defective laser unit and would need to be replaced. The part number is 122N00276 and available below:
http://www.iteminconline.com/122n00276_122n00276-122n00297-xerox-3600-laser-scanner-unit-lsu.htm
Mar 08, 2016 | Xerox Phaser 3600DN Laser Printer
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
My XEROX 6180N printer has vertical white lines running on left side of page and also has starting making loud squeaking noise while printing? Any ideas?
Try a different cartridge. While line typically means that no toner is being applied to the drum in that location. Would also explain the squeaks.
Sep 02, 2015 | Xerox Phaser Office Equipment & Supplies
Xerox 3600 printer service manual
Hi go to the follow link or copy and paste it into your browser
www.manualslib.com manual 374530 Xerox-Phaser-3600.html (put / where the spaces in the address are)
Aug 06, 2014 | Xerox Phaser 3600 PCL 6
How do I stop my phaser 3600 from squeaking?
Have you try to clean its gears? You can use some pressurized air (dust off), and a little of light oil (DW40) ONLY for metallic parts.
Sep 18, 2012 | Xerox Phaser 3600DN Laser Printer
How to replace tray 1 rollers
sir you can download service manual xerox 3600 in this link
http://www.itechmv.com/wp-content/uploads/2014/02/phaser3600.pdf
hope that it will help you
Sep 14, 2012 | Xerox Phaser 3600DN Laser Printer -...
Xerox 6250 squeaks when printing
The image unit 108R00591 is known to squeak.
You can also isolate the motors in diags. (Power-on the machine holding the back arrow and the "i" button and scroll to Motors) If any of them squeak then you have another suspect.
Jul 20, 2010 | Xerox Phaser 6250N Printer
Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Feb 24, 2010 | Xerox Phaser 4500/YDX Printer
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox Phaser 3600DN Laser Printer Logo
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
