Question about Echo Gas Blower 162 MPH 450 CFM Blower PB500H
Wont stay running on run
Runs on choke but stalls when I push the lever to run
5 Suggested Answers
  • 150 Answers
SOURCE: when you first start the blower on choke then you
check carb adjustment screws. Also may have a blocked muffler. There is a spark arrester screen that becomes blocked. Usually 2 screws hold this in place at muffler exhaust, remove screen and use small tourch to burn it clean.
Posted on Sep 27, 2010
SOURCE: starts up fine but when
The question posted is not clear enough to advice on what to do, i will need more information as regards the device and what the problem is.
Posted on Oct 13, 2010
NomadTrucker
  • 166 Answers
SOURCE: pb-413 blower. starts w choke,
Most likely there's a problem with fuel supply - choking cuts air supply optimizing the air/fuel mix. Most common solution is to check and clean the carburetor.
If there's a tiny fuel filter in the fuel line between tank and carburetor check it on excessive pollution. Replace it when necessary.
When opening the blower for carburetor cleaning - also check the airfilter and replace when dirty.
If never opened the blower - take pictures with a digital camera at each step. The pictures can help with assembly after cleaning.
Posted on Jul 11, 2011
vincob
  • 718 Answers
SOURCE: Blower starts when choking but dies when I move
Your unit is most likely equipped with a Walbro carb take it off and get the letters and numbers stamped into it and buy a carb kit for that model and rebuild it. Go to smalleng.com to see video on this matter. Good Luck...
Posted on Aug 24, 2011
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
Why is choke button stuck in the on position and the on/off adjustment lever just runs it until today?
normally on most saws the choke lever is manually set and then stays on till one squeezes the trigger (throttle) then it should pop off and run normally(assuming saw is warmed up enough) if this is not what happens sometimes a outer case interferes with the levers and wont allow for proper movement (shifted), also there's a few springs in there that do all the moving these can pop off there mounts and not allow proper lever moving as well
Jul 30, 2015 | Garden
I need to rev the throttle to prevent the engine from stalling.
Try checking these two things: idle adjustment (usually milled screw on the carburettor) or there could be a problem with the governor - this is usually a plate that is driven by the airflow from the cooling fan, check that this moves freely (usually a shaft from the cooling fan on to the carburettor butterfly valve), if this is not free, then the engine will only run on idle, will not reach running speed, garden debris can cause it to jam...
Nov 06, 2013 | Ardisam Earthquake Mini Cultivator 43cc...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
04 polaris wont stay running without choke on
You will have to replace your pilot jet. thanks, Jason
Dec 01, 2009 | Polaris ATV
I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
Aug 24, 2009 | Garden
Will not run unless on choke
carb needs to be rebuilt and fuel filter changed in gas tank
Aug 13, 2009 | Garden
Echo Gas Blower 162 MPH 450 CFM Blower PB500H Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
