Question about Dyson Vacuums
No suction - Dyson vacuum
Dyson vacuum lacks suction - throws dirt out of the back
  • Anonymous Mar 30, 2014
    canister button is stuck on my Dyson DC21 vacuum
  • 328 Answers
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Posted on Jun 19, 2009
My Dyson DC14 picks up on hard floors and the hose works, but lacking suction on carpet
The DC14 has belts in the clutch that become stretched and lose elasticity. Even with great suction a vacuum will not clean well on carpet if the brush is not spinning fast enough.
Mar 04, 2018 | Dyson Vacuums
Brand new dyson DC40 has no suction at bottom
Hi Marin, it's Jack at Dyson.
DC40 is a powerful mid-size Dyson upright vacuums, and we wouldn't expect you to have any concerns about performance on hard flooring or carpet. As long as the machine is used and maintained as described in the User guide we would not anticipate a change in performance, and we're on hand to help if Dyson owners need assistance.
It's important to note that for effective pickup, the cleaner head needs to form a close seal with the floor surface. Simply placing a hand under the cleaner head does not give an accurate idea of suction as you're not creating a seal, as you would be when you place your hand right across the end of the wand or hose. If you turn on and recline the vacuum, turn off the brush bar then lower the cleaner head onto something like a sheet of newspaper, you should see the newspaper held tightly against the soleplate by the vacuum's powerful suction.
We're keen to discuss this with you, and to help ensure your DC40 is working as well as it should be. Please email your full contact details to my colleagues at askdysonUS@dyson.com, and one of our experts will be in touch as soon as possible to provide further assistance.
Feb 14, 2015 | Dyson DC40 Animal Upright Vacuum -...
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
No suction after assembly
Sounds like you have a tube misaligned. Take the tubes that lead to the filter off and put back on. Most likely the solution
Feb 13, 2014 | Dyson DC25 Bagless Upright Vacuum
Dyson DC25 is barely picking up, but what it is picking up is not going into the cannister,
Your problem is posted in the wrong category, so probably no-one reading here (Telescopes and Binoculars etc) will have the solution.
I do know that Dyson maintains Tech Advice lines worldwide. Look here
http://www.dyson.com/
select your region, then look for a Tech Advice number you can ring
Jun 10, 2012 | Dyson DC25 Ball All-Floors Upright Vacuum...
Handle vacuum no suction
I have made a video of the two most likely causes for lack of suction in the handle of your dyson DC07. Watch the video and see if it helps. The other thing to check is your washable filter, this can cause a big resuction in suction if dirty. If this is helpful take a moment to leave a testimonial or a thumbs up please.
Hope your back to full suction soon. :)
Oct 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson Animal 14 is not producing enough suction to pick up dirt. What should I do?
Check for an obstruction. There are several cleanout ports built in to make this easier.
Nov 14, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Noisey DC07 Bagless Upright Cyclonic Vacuum; lack of suction...
Hi there it's SmartAlec from NelsonVacuums.com.au here. It is very likely you have a problem in the radix assembly or the filter is actually worn out. Basically to test either simply remove one then turn it on to test. If it runs better with out the filter (washable is most likely culprit) simply purchase a new one. If it is the radix assembly that is the problem it is possible to clean inside the little tubes by taking off the top and literally clearing dirt and fluff out with the help of a coat hanger. Alternatively a new one can be purchased. If you are in Australia or New Zealand I can help you with either part. Just put in a request via the email link n our website. Hope this helps regards Alec
Oct 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Animal with no suction from floor brushes
Check the canister seal for dirt or gaps. This is normally where the vacuum leak is.
May 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson lsoing suction
Hi.
Turn the 3 plstic screws under the machine to unlock position & remove sole plate,
You can now see if belt has snapped & replace it.
http://dysonmanuals.inc.io/
Chris.
Nov 21, 2007 | Vacuums
Vacuums Logo
484 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
