Question about Rockwell Crafts & Hobbies
Machine humms when off
Also need info for setting blades
Have a brother sawing machine it just humms when i press ladel
would be something wrong with the foot petal or the motor, make sure the foot petal is snuggly connected into the plug of the machine, and if it is, then the machine needs to be checked
Mar 20, 2014 | Singer Sewing Machines
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
High pitched humm
Need more info on the vehicle please.
May 13, 2013 | Cars & Trucks
Central air unit will not run
Check capacitor. If unable to check just replace with new one cost about $20 or less this is problem 90% of time.
Aug 29, 2012 | Heating & Cooling
I need a kneading blade for a model ABM6200 Welbilt bread Machine. Where can I purchase this item? I cannot even find any info on this model...? Any assistance would be appreciated! Thank you in...
I have a kneading blade for the ABM6200 welbilt bread machine. I sent it out to have it teflon coated and it is really great. Unfortunately my bread maker broke and I never installed the blade. I have the blade and the manual if you are still interested.
Oct 04, 2010 | Welbilt Microwave Ovens
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
After my dishwasher fills with water, and starts to clean it doesn`t do anything but humm.
more than likely something is sticking in pump, remove access panel and reach into motor opening and try to turn motor over by hand if you can (using motor cooling fan blades) .This problem happens more often if machine is used seldom
Sep 30, 2010 | Amana 24 in. DWA22A Built-in Dishwasher
Motor humms but blades do not rotate
Try replacing the capacitor which is the cheaper option (about $20) if still don't work replace the motor.
Jul 31, 2009 | Heating & Cooling
Crafts & Hobbies Logo
41 people viewed this question
Top Rockwell Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Rockwell Craft and Hobby Expert? Answer questions, earn points and help others
