Question about Honeywell WAP Wireless Access Point for Ip Cameras
How to setup password on honeywell wap plass - Honeywell WAP Wireless Access Point for Ip Cameras
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
May 12, 2011 | Computers & Internet
Have a Chinese smart phone and need the detail setup for gprs rogers communication
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to goam.com (lowercase), if not work, try "internet.com"
8.Edit Username to wapuser1
9.Edit Password to wap
10.Edit Auth Type to Normal
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://mymobilehomepage.rogers.com
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 208.200.067.150 and the port number is 80
10.Edit Username to wapuser1
11.Edit Password to wap
Select back or done
Select Activate Account
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mms.gprs.rogers.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 172.025.000.107 and the port is 80
Edit the Username to media.com
Edit the Password to mda01
Select Done or Save
Make sure to activate the profile and you are good.
Restart the phone.
COUNTRY: Canada
CARRIER: Rogers
Internet Settings
APN: internet.com
USER: wapuser1
PASSWORD: wap
HOMEPAGE: http://mymobilehomepage.rogers.com
PROXY: 172.025.000.107
PORT: 80
MMS
APN: media.com
USER: media
PASSWORD: mda01
HOMEPAGE: http://mms.gprs.rogers.com
PORT: 9203
Mar 01, 2010 | RIM BlackBerry Curve 8310 Smartphone
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
No internet connection it is a unlock phone from t mobile to att
Hai, Go into Web Sessions and change the Internet and MMS settings to those appropriate for AT&T. If the T-Mobile settings are locked, create new settings and make them the the default. Each carrier has its own setting but those settings are the same for any phone on that carrier's network.
Browser Settings (in web sessions): ---------------------------------------------------------------------------------------------------- Name: Cingular Wireless Internet
Homepage: http://device:home or http://device.home Service Type 1: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------- MMS Settings (in web sessions):
Homepage: http://mmsc.cingular.com Service Type: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------------------ MMS Settings (in Message Center>>>Message Setup>>>MMS Message Setup): Hide fields: Cc.Bcc.Priority Autosignature: Download: Automatic Filter: Expire After: 5 days Reply Type: MMS Size Limit: None Server Info: Cingular MMS>>>Select Server Info>>>Current Server>>>New: Service Name: Cingular MMS
Server Name: http://mmsc.cingular.com Web Session Name: Cingular MMS.
Some settings may not have to be entered for all phones because they are set at the default for those models. You can leave the User Name and Password fields blank.
Aug 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
Internet and MMS settings for ATT carrier with unlocked samsung f-480
AT&T Settings
1) Start>Settings>Data Connections>Menu>Edit Connections
2) Open Dial-Up Connections. Delete all Orange Settings.
3) Open Proxy Connections. Delete all Orange Proxy Settings.
4) Create PROXY CONNECTION:
Description: mMode
Connects from: The Internet
Connects to: WAP network
Proxy (nametongue.gifort): 10.250.250.54:8080
Type: HTTP
Username: (blank)
Password: (blank)
5) Open GPRS Connections. Delete all Orange Settings.
6) Create a new GPRS CONNECTION
Description: ATT GPRS
Connects to: The Internet
Access point: proxy
User name: (blank)
Password: (blank)
Primary DNS: (blank...will later default to 0.0.0.0)
Secondary DNS: (blank...will later default to 0.0.0.0)
IP address: (blank)
7) DATA CONNECTIONS
Internet Connection: ATT GPRS
Work Connection: Automatic
WAP Connection: Automatic
Secure WAP Connection: Automatic
8.) In Internet Explorer, Menu>Options>Connections
Auto Detect Settings: Unchecked
Select Network: Wap Network
9) MMS SETUP.
Inbox>Menu>Options>Account Setup>MMS>Menu>Edit Connections.
Delete any Orange Settings that are there.
10) Menu>Add
Description: ATT MMS
MMSC Address: http://mmsc.mobile.attwireless.net
Data Connection: The Internet
Gateway: WAP 1.0 Gateway
IP Address: 10.250.250.100
Port: 9201
11) Click Done twice to return to the MMS Setup Screen
Server: ATT MMS
Download Messages: Automatically
Outgoing Message Size: Less than 100KB
Allowed Message Types: Personal
Click DONE.
Cingular Settings
WAP
***First Step***
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
***Second Step***
Select WAP
6.Edit Homepage to http://device.home
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
You should now see a Black [G] in the upper left of your screen.
MMS
Select Edit Profile
Edit Home Page to http://mmsc.cingular.com
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
May 02, 2009 | Cell Phones
Can't set up wap or gprs or mms for orange payg
Goto Home
Goto Entertainment
Goto Services
Goto Data Account
Choose GPRS
Create a new profile (give it a name)
APN payandgo.o2.co.uk
Username payandgo
Password your password
Auth. Type Normal
2 Edit Browser Profile
Go Back to the Entertainment > Services Menu
Choose WAP
Choose Settings
Choose Edit Profile
Create a new one, call it sthg and choose O2
Choose Edit Profile
Rename if required
Homepage: http://wap.o2.co.uk
Data Account: Select the Account setup in 1 Above
Connection Type: Choose HTTP and set proxy to 193.113.200.195 and port to 8080
Username and password should remain empty
hope it helps
Apr 05, 2009 | Cell Phones
Gprs
Which Carrier? You can try this if its t-mobile, otherwise find the carrier specific settings and replace the t-mobile with the carrier settings.
Data Profile Setup:
  1. From the main menu select My Data > WAP > WAP Profile
  2. Scroll to an empty profile and select Edit
    • Set Profile Name to T-Zones GPRS
    • Set Homepage to wap.t-zones.com
    • Leave User ID and Password blank
    • Set IP Address to 216.155.165.050
    • Set Port to 8080
    • Set Show images to ON
  3. Press Save
  4. Select Activate
MMS Setup:
  1. From the main menu select Messaging > MMS > Settings > WAP Profile
  2. Scroll to T-Zones GPRS and select Activate
  3. Press Back
  4. Select MMS Server
  5. Scroll to an empty profile and select Edit
  6. Press Save
  7. Select Activate
  8. Power cycle phone and test
Jun 06, 2008 | NEC e122 Cellular Phone
Unlocked european phone MMS
wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Homepage: http://device.home
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Web Session Name: (Choose the Web Session you created for MMS)
set to default
Mar 10, 2008 | Motorola Mobility RAZR V3
Cant pxt or recieve tone downloads (parallel import phone)
Please verify that your settings are as follows, and then you should be all set!
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
(if not there select "new")
Scroll to "Edit," press Select.
Validate the following parameters:
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Service Name: MMS
Web Session Name: MMS
Dec 14, 2007 | Motorola Mobility RAZR V3
Honeywell WAP Wireless Access Point for Ip Cameras Logo
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
