Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum power head stops - Rainbow E series Canister Wet/Dry Vacuum
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have power and air suction, but the beater will not turn and the belt is fine.
Check that you are getting power to the brush roll motor. Many Rainbows have a reset button on the power head.
Jan 31, 2014 | Rainbow Vacuums
Rainbow power head dusty
Have you checked the channel from the brush roll area to the hose for blockage? Dust accumulation is usually a sure sign of an obstruction.
Nov 07, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum wet, power nozzle isn't working now was and just stopped
Does your version have a light on the power nozzle and if so, does it come on?
RainVac
www.rainvac.com
800-523-0510
Jul 29, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I think the switch on the Rainbow E-series electric hose went bad. Is there an easy vway to verify it's the switch?
Hi, the only way, is to test that it has power at the swirch with a circuit tester or voltage meeter, or test the plug on the handle where you attach your power head power cord, or Rainbowmate power cord to.
If it does not get power there, then test that the switch is getting power.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 11, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Power head Motor
type rainbow vacuum parts in your search browser and there should be tons of sites where you can get the parts .if you want to call all-type vacuum and janitorial supply its 314-275-8006.ask for lisa she can probably get it for you.
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
41 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
