Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Need seat switch for Husqvarna ELS 725 - Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 15 Answers
Try www.repairclinic.com.
Posted on Jun 22, 2014
How to solve problem with releasing brake on zero turn husqvarna the engine dies not seat switch
This sounds like the seat switch. Keep in mind newer model seat switches cannot be jumped or disconnected.
Mar 17, 2015 | Husqvarna Garden
ON MY HUSQVARNA TRACTOR MOWER,YTH150. WHEN I TAKE MY FOOT OFF THE BRAKE/CLUTCH IT CUTS OUT.
This sounds like the seat switch has either gone bad or is not connected properly. Remember you cannot jump over or avoid the seat switch. Check to insure the wiring is connected to the switch on the seat, if it is connected, I suggest replacing the switch.
Mar 10, 2015 | Husqvarna Garden
Why does my husqvarna 2448 die when blade engages
I agree with Phil. The safety switch under the seat on my Husqvarna is very sensitive. Sometimes if I hit a large enough bump, it's enough to disengage the switch even with me on the seat.
Jun 20, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a 2005/2006 Husqvarna GTH 2654 Garden Tractor with a Briggs & Straton ELS 725 engine that I am having troubles with. I have had other problems with this engine but this is something different....
check the operators manual but I think that by allowing the engine to be at high rpms then dismounting from the unit , activated a seat safety microswitch that cuts the rpms back or is designed to shut down the engine
Talk with the manufacturer dealer about the problem
Mar 23, 2017 | Husqvarna Garden
Have a 22 ohv B&S els 725 v twin want recharge a new battery
If you want to recharge a "new" battery you should use a trickle charger and leave it on over night. Remove the ground side wire from the battery before charging. let us know
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 24 HP model ELS 725 mower stopped running have power, turns over, does not fire. please explain your answer with instructions for ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN...
A great expedient spark tester can be made from an old spark plug that you know is GOOD.....clip or grind the grounding terminal ( the terminal which goes over the top of the electrode) back until you have a gap of 1/8 to 3/16 of an inch between the terminal and the electrode...Remove both plugs from the machine and attach your new test plug to the plug wire. Ground the plug by placing it on the head or the shroud. Turn the machine over. If you are getting fire you should see a strong blue spark shoot from the electrode to the terminal. If you have no fire then you probably have a bad ignition coil, bad plug wire, or maybe just a bad seat, brake, or PTO safety switch...I'd check these first. Also check your ignition switch in the run position with a test light to be sure it is good....hope this helps... ;-D
Jul 08, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
We have a Husqvarna Rider, model YTH180. It's
whats rough the motor if so you could have bad gas or bad plugs or somethin els you may need to get that to a shop
Sep 27, 2009 | Husqvarna Garden
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
