Question about Vivitar ViviCam Cameras
Vivitar 5150s camera memory card won't work
Sd or sdhc won't work
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 | Cameras
Can you use SDHC when manual says SD?
An SDHC card is not an SDHC card. While it fits into the same slot, it will not work unless the device is designed to also work with SDHC cards. SD cards go up to 2GB in size, SDHC cards go from 4GB to 32GB in size. Unfortunately, Vivitar seems to be a little fuzzy on the distinction between the two.
In your particular case, you should be able to use any SD card, or any SDHC card up to 16GB in size.
Dec 03, 2011 | Vivitar Cameras
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Can I use a 4GB SDHC memory card with Vivitar 5385 camera
No. The 5385 works with SD cards, not with SDHC cards. You're limited to cards 2GB and smaller.
Nov 07, 2010 | Vivitar ViviCam 5385 Digital Camera
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
DVR 518 question regarding sd card compatibility;- will the product accept a SDHC card to 8gb I have difficulty in getting a standard SD card
The manual is not very precise but you cannot get normal SD cards that go to up 8gb, the highest is 2gb.
When they say 8gb they must mean SDHC.
Hope this helps.
Mar 19, 2010 | Vivitar DVR518 Camcorder
Just wondering what memory card i need as a 4gb sdhc card doesnt work it saying card fail
Your camera may not be able to use SDHC cards. Try an SD card instead (they only go up to 2GB).
Mar 16, 2010 | Vivitar ViviCam 5150s Digital Camera
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Sdhc question
no it is not, sorry.
External Memory: SD Card (up to 256MB) ( Card not included)
From your specification sheet
http://www.amazon.co.uk/Vivitar-Vivicam-3935-Digital-Optical/dp/tech-data/B0007XQFJK/ref=de_a_smtd
Hope this answers your question.
Regards
Richard.
Nov 29, 2008 | Vivitar ViviCam 3935 Digital Camera
Cameras Logo
13 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
