Question about Precision Camera Torque Angle Meter/gauge For Head Bolts And More 28100
Z10xep head torque
Can i reuse the head bolts of a corsa 1.0L z10xep?
CYLINDER HEAD AND BIG END BEARINGS TORQUE SETTINGS FOR OPEL CORSA 2005 1.6LT PETROL MODEL SOUTH AFRICA
i think the 1.6 ltr was only for some markets the engine i think it may be is! cyl head head with new bolts, 25nm +90 +90 +90 + 45 degrees the big end/conrod bearings 25nm +30 degrees thats if it a vauxhall/general motors engine. it may not be
Sep 29, 2016 | 2005 Opel Corsa 1.6
Head bolt torque?
M11 bolts: 1st step; - 22 ft./lbs. 2nd step; - turn 150 degrees M8 bolts 9-10: 1st step; - 11 ft./lbs. 2nd step; - turn 75 degrees Note: Do not reuse cylinder head bolts. Do not allow oil on cylinder head, head bolt bosses.
Apr 27, 2016 | 2007 Suzuki XL-7
Torque specs for opel corsa 1.4 comfort utility 2005 model
Assume you are needing the cylinder head torque specs?
The head bolts are angular torqued and best practice is to fit new bolts and ensure all the female threads are thoroughly cleaned. I recommend greasing the bolt threads and washer faces.
The initial torque (following a spiral pattern) is 25 NM followed by angular movements of (degrees) 90 + 90 + 90 + 45
I generally start the engine and thoroughly warm up and allow it to cool before the final 45.
Nov 09, 2015 | Opel Corsa Cars & Trucks
Do I need to replace head bolts on my 2003 Saturn l200
Head bolts are typically a Torque Angle to Yield specification, an example 100NM plus 75 to 100 Degrees of angle. You should be able to reuse the bolts, assuming that they have not been reused before. The bolts are plastically deformed when they go into yield, typically you can reuse them 1 to 2 more times. It is stated in the service manual to replace the bolts because it is never known how many times in the past they may have been retightened. So if you have a good history of the vehicle, and know that the head has not been removed, your pretty safe to reuse.
May 18, 2014 | 2002 Saturn L-Series
Samy thanks again for your reply back is that mean mechanic can reuse the old bolts providing they come un damaged ? ??
I'm not Samy, but many bolts stretch and can't be reused, especially head bolts and frame bolts.
May 13, 2014 | 2005 Jeep Cherokee Limited
Opel corsa c
What spark plug wire? A 2008 Corsa has a sealed coil pack connected to all four plugs and bolted to the cylinder head
Apr 03, 2014 | 2008 Opel Corsa 1.4
Head torque settings
Here you go.
Cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs
Mar 28, 2014 | 2005 Opel Corsa
Precision Camera Torque Angle Meter/gauge For Head Bolts And More 28100 Logo
29 people viewed this question
Top Precision Camera Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Precision Camera Measuring Tool and Sensor Expert? Answer questions, earn points and help others
