Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Grinding noise carousel continues to grind when you open door
nliwilson
  • 114 Answers
SOURCE: Grinding noise when playing Premier Manager 2008
If your not getting the same problem with other games and you have cleaned the laser lens then it's going to be down to a faulty disk. The store you purchased the game from should replace it for you or you can have it replaced by Zoo Digital but this involves sending the disk to them and can be time consuming.
Posted on Aug 23, 2007
SOURCE: grinding noise
clean the dust out of the fan,,check and make sure fan is clearing the metal grid it sits on. also,,clean and lube the slider shafts that the laser rides on. use only a drip or 2 on each shaft and use hair clipper oiil or sewing machine oil.
Posted on Nov 20, 2007
SOURCE: Grinding Noise
sounds like you have a problem with the cooling fan
Posted on Dec 31, 2008
kathleenmyer
SOURCE: Sony dvd player DVPCX995VMakes grinding noise and door won't open
I was able to fix this myself, however, I did get instructions from Sony that may or may not work. My solution was:
Unplug the unit and carefully (so the disks don't shift) move to a location where it can be easily worked on.
Remove the 9 screws holding the cover on. 2 on top, 2 on each side, and 3 at the back, along the top edge.
Carefully, may need some wiggly remove the cover. There are some rubber pads at the front of the unit that hinder the cover from sliding. Slightly wiggling and pulling to the rear will dislodge it.
Confirm all disks are properly aligned on the carousel.
Pull out any disks that are askew. They will be replaced later in the same way disks are added, through the door.
Look in the rear where the laser unit is.
Carefully slide out disks near the laser. You'll have to move some in order to tip others out.
By taking out 6-10 disks, you'll probably find there's one partially lodged in the laser unit. With adjacent disks removed you can slide the "stuck" disk out.
Plug in the unit and test to see if the grinding stopped.
Unplug the cord.
Replace the cover with the 9 screws. Some wiggly and pushing forward is needed to reseat the cover at the front.
Carefully move the unit back to where it was.
Replace cables and plug in.
Return the disks removed according to the instructions.
This took me about 15 minutes from start to finish.
The following was provided by Sony. I don't know if this works as I had fixed it before Sony responded.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons. NOTE: This step may not apply to all models. DISC1 is not available on all DVD players.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Oct 12, 2009
  • 56 Answers
SOURCE: It's making a grinding noise.
It's the zoom mechanism. You either have dirt / sand trapped in there or the gears have broken.
Posted on Nov 27, 2009
Why does turntable rotate with door open?
The door switch could be stuck in the closed/on position. The electronic circuits could be malfunctioning. When the door is open, I sure hope than the microwaves cooking are not "ON". That could result in a very dangerous situation for you.
Dec 05, 2015 | Microwave Ovens
Can I simply defrost freezer to solve a grinding noise that stops when I open fridge doors and gets louder when I open freezer doors?
Not knowing the type of Refrigerator, frost-free or cyclic-defrost-
My opinion is, the noise may be generated from the Fan in the Freezer -compartment,
It is mostly situated in the freezer, behind a removable panel at the rear wall, The panel has a grill, or is slotted to allow the cold air to flow.
The fan may be worn out.
You may hear a grinding or squealing sound.
The fan-blade may be touching (striking) something,
The blade may have moved along its shaft and strikes the housing.
It may strike solid ice ,
the ice can form, if there is a fault with the Automatic-Defrost.
You need to confirm if the fan blade rotates freely.
Do you know how to do that?
K. AUS
Mar 11, 2015 | Refrigerators
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Can't reattach the door to the trolley and grinding noise, won't move
Pull straight down on the rope and release. Then you should be able to run the opener and the two halves of the trolley will click together. Sometimes you need move the door by hand to get this done. The grinding noise is most likely the drive gear stripping. Remove the cover from the motor unit and it should be obvious.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My printer is making a weird noise and the power light just blinks
Turn off the Printer
open the Front access Door, Check if there is bits of paper or dirt on the ROD that moves the Cartrige/carriage.
Move the Carriage freely 5-6 times from left to right ( it should move smoothly )
Remove the Cartridges, Clean the contacts on the Cartridge ( golden Contacts)
Open the Rear Access door, Clean the Rollers with lint free cloth.
Close the Rear access door and front door
Power on the Printer. If the grinding noise continues, Unplug the power cable from back of printer ( while printer is on ) and while holding the # and 6 button, connect it back.
It should go thru alignment process and the grinding noise should be gone. If it doesnt, probably.. its time for new printer of HP again.
Jun 24, 2010 | HP PSC 2410 All-In-One InkJet Printer
PRINTER MAKES A LOUD SOUND LIKE A MACHINE GUN WHEN IT PRINTS
Jun 24, 2010 | HP Officejet J5780 All-In-One InkJet...
Unplug the cord.
Oct 11, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
