Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Kitchen Aid microwave door -- outer glass
Kitchen Aid microwave door outer glass shattered spontaneously. What to do?
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Posted on Aug 25, 2009
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Main oven door outer glass panel shattered
I doubt you will get it cheaper any where, Zanussi is a bit of a closed shop.
If you can let me have the exact model no and the er number, I might be able to help you.
As for the reason it shattered, there are numerous reasons for this to happen, too many to go into, but it is a very common problem with cookers..
They do just go without any warning.
A cold kitchen could indeed be a factor, a badly fitting door is another factor, i could go on and on and on!!!!!
There is no one thing it can be put down to.
Plz let let me have the details I ask, and I will see what I can come up with.
Dec 12, 2008 | Ovens
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
562 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
