Question about Craftsman Garden
Grease fitting size - Craftsman Garden
How can I remove the pressed in grease fitting on a 1930 Ford
Grab it with a good set of vice grips and work it out, I have had grease fittings that won't take grease and some of them the parts had to be removed and the lube hole cleaned out. you can also buy a grease injector that is a hollow barrel with a plunger that fits down in it and you pull out the plunger fill the barrel with grease install the plunger, place the injector on the grease fitting and hit the plunger with a good size hammer
Jan 12, 2016 | Ford Cars & Trucks
I need to grease front nickel on my Toyota 79 pickup and can't find grease fitting
Many do not have grease fittings, but almost all come with a hole to install one. One on each of the ball joints. Check with auto parts store for the right size.
Apr 05, 2014 | Cars & Trucks
How do I replace a rusted out threaded grease fitting on my omc 165 i/o? I bought new fittings but now the hole is too big.
You will need to purchase a Heli Coil kit. This kit will allow you to drill the hole to a larger size, then a special tap in the kit will rethread the hole to a special thread size, then the helical (threaded insert) will be installed into the larger hole, restoring the threaded size back to what it once was. Great tool, used it many many times.
Aug 22, 2010 | Boating
Where are the grease fittings ?
Manufacturers generally removed grease fitting from suspension part back in the 80's. Some put a removable plug in the ball joints, tie rod ends, etc, which could be removed and grease fittings installed in their place, but most have sealed and permanently greased. In other words you can not lubricate any fittings. If parts go bad, the replacement suspension parts generally have grease fittings.
Aug 10, 2010 | 2000 Mercury Grand Marquis
What is the size of replacement grease fittings for a 2000 chevy s10 zr2 ???
common sizes are 1/8 PTF and 1/4 PTF. Go and buy some this size and youll have what you need.
Jun 25, 2010 | 2000 Chevrolet S-10
Is their any grease fittings on it
It's very unlikely. You will only find grease fittings on full size trucks these days.
Oct 06, 2009 | 2006 Dodge Stratus
Reebok demon 2007, tools for servicing it?
If you are re-greasing the hubs you need a minimum of 4 speciality tools. A 12mm, 13mm, 14mm, & 15mm, cone tools are required for this job. There are many brands of cycling grease out there. Any bike shop, (usually not department stores) have bike grease, although you can use automotive grease. GO TO Parktool.com for tips.
Mar 22, 2009 | Cycling
Lubing after an oil change.
ALot of newer cars and turck do not have any fittings to grease. thats just the way it is. i agree its not a smart idea either.
dont spend too much time hunting them down.
Feb 09, 2009 | 2005 Mazda Tribute
GREASE FITTINGS
there are either grease fittings or plugs where they go, the fittings will be in the ball joints and the tie rod ends. should grease about every 6,000 miles or so, if u go through water allot more often
Jan 15, 2009 | 2008 Hummer H3
Garden Logo
14 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
