Question about Ricoh Aficio 1035 Copier
Ricoh 1045 codigo de error sc 670 - Ricoh Aficio 1035 Copier
  • 990 Answers
SOURCE: codigo sc 440 aficio 350 (fotocopiadora
Hello sir; SC-440 means main drive motor locked ,suggestion; 1, check the connector isn't connected, 2, replace main motor.
Posted on May 06, 2009
SOURCE: tengo una fotocopiadora ricoh aficio
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Posted on Dec 07, 2009
  • 1297 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
SOURCE: Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
joel_baleta
  • 155 Answers
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Posted on Jan 26, 2010
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
CODIGO DE AVERIA SC 553 RICOH MP 8000
la fotocopiadora marco sc553 y no se desbloquea que debo hacer
Jan 31, 2013 | Office Equipment & Supplies
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
Ricoh 1045 error code sc 672, 961
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Codigo sc 440 aficio 350 (fotocopiadora
May 06, 2009 | Ricoh Aficio 450 Copier
Showin cover open but doesnt indicate plus sc code 670
I looked up the error code in the manuals for the 450 and 450e,I tried sc 670, 607, 706 and 760 NONE or those codes exist in either one of my manuals! Sorry. Wish I could help
Apr 03, 2009 | Ricoh Aficio 450 Copier
Tengo una fotocopiadora ricoh aficio 1075 y me sale el aviso SC 541 que debo hacer para quitarle este codigo de error
Buena suerte...
Jan 23, 2009 | Ricoh Aficio 450 Copier
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 1035 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
