Question about Furinno Hidup Adjustable Cooler Fan Notebook Laptop Table P
Broken leg FURINNO Hidup Adjustable Cooler Table.
Plastic joint broken
How to attah table leg frame to table bottom panel?
Not quite sure what part(s) you're having problems with. But I'll tell you what I know...
There is a table top (a bunch of boards joined edge-to edge). Under this top is a skirt. The skirt is typically a box that doesn't need the table top for structural support - the legs are attached to the skirt (in the corners). Depending on how the skirt is designed, the legs may be removable (makes the skirt more complex).
Attaching the skirt to the table top can be done in many ways. The best way is to allow for expansion/contraction of the table top. The edge to edge combination of the table top makes for a larger expansion/contraction than the skirt. So the skirt should have a slot instead of a hole for a screw through to the table top.
If you just screw everything together, it will work. But if moisture and/or temperature changes, you may separate the table top, or joints in the skirt.
Apr 23, 2015 | Saws
I would like to buy 6 more legs and 1 more shelf.
Writing term paper is not an easy task for some students. They always searching for the term paper writing services for Buy Term Paper Online. A genuine writing service helps them by guiding properly to complete their term paper.
Feb 27, 2015 | Furinno 3 Tier Multipurpose Storage...
A few of us want to buy a massage table together but we are all different heights. How high should our table be?
Nearly all massage tables now come with adjustable height legs and for you that sounds essential. If you can't adjust the height, the smaller people won't be able to get full reach across the table and taller people could hurt their backs leaning down. So make sure you put that feature on top of your buying list.
Aug 13, 2012 | Furniture
Are drafting tables one set height is can it be adjusted?
Most drafting tables can be adjusted anywhere from 30 to 50inches in height. When purchasing adrafting table, it is important to confirm with the salesman that you have thisoption.
May 29, 2012 | Furniture
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
What can be done with a scoll saw, table legs?, what uses is the scroll saw for
Scroll saws use a small thin blade that runs up and down very fast. It is used to cut curved designs out of flat wood. Table legs are made on a lathe, it spins a square or round piece of wood to make legs, baseball bats.
Mar 01, 2011 | Garden
Buzz lightyear broke his leg
my buzz lightyear has a broken leg joint :( please help me!8f64e74e-25f3-4352-85a1-1dc0469e1a36.jpeg
Dec 27, 2009 | Thinkway Toys
How do I remove the legs from Leapfrog Musical Table
Turn the table on its side. On the top of the outside of the legs are two slits, where they connect to the table. Slip a butter knife in the area between the slits, and press in (not up or down) hard! The legs will pop off in a few tries if you do it hard enough :o)
Jan 15, 2009 | Toys
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Furinno Hidup Adjustable Cooler Fan Notebook Laptop Table P Logo
35 people viewed this question
Top Furinno Computers & Internet Experts
David Payne
David Payne
Are you a Furinno Computer and Internet Expert? Answer questions, earn points and help others
