Question about Brother CS-80
Brother cs 80 rubber ring - Brother CS-80
4 Suggested Answers
SOURCE: Brother CS-80 will not always thread the needle
I get this problem too. I found that it might be because I've moved the wheel while sewing previously and the needle doesn't go back to where it's supposed to be to be auto threaded correctly. To solve it, I just push the canister down until the threading parts are lowered. Once I see where the threader is positioned, I use the wheel to adjust the needle height to where the threader is, then I push the canister down all the way, and the needle is threaded. Hope it works for you!
Posted on Apr 11, 2010
hmerchant110
  • 7191 Answers
SOURCE: cs 80 brother sewing machine
You can download the free instruction manual in PDF format from Brother CS-80 support website by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Sep 05, 2010
ju222dy
  • 8 Answers
SOURCE: part for bobbin winder cs-100
http://www.sewingpartsonline.com/ has the part you need. It's called a bobbin winder "tire"
Posted on Aug 10, 2012
How do I open the machine to replace the bobbin ring on a Brother CS-80?
Here's MY answer.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
May 11, 2014 | Brother CS-80
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Feb 27, 2014 | Brother CS-80
It's a nasty job, bring it in for service, you'll only make it worse.
Getting the cover off my brother cs 80 sewing machine
If you have a two piece body machine it is best left to a sewing machine machine shop
Sep 09, 2013 | Brother CS-80
Bobbin doesn't wind on my cs-8080 innovis
On my one the rubber ring had degraded into a sticky mess and come off the pulley-shaped wheel on the bottom end of the winder shaft. It had stuck itself to the casing by the shaft bearing. Using Q Tips and nail varnish remover I managed to clean it all off.
To access the screw that holds the bobbin winder mechanism in the case; you first need to remove the screws that hold the circuit board in place and ease it out of the way.
Aug 08, 2013 | Brother CS-80
The bobbin winder will not work
My bobbin winder worked great for a while. The last time I used it it worked fine. Today I got it out and it would not spin the bobbin to wind it. I got on a forum and they talked about the O Ring deteriorating. I took the machine apart and found no evidence. No melted rubber, shavings NOTHING. In fact that there was no evidence the O Ring had EVER been there. I looked in my husband;s stash and found several sizes until I found one that fit. I put it in the groove where it should had been and it is working great now.
Jul 06, 2012 | Brother CS-80
Part for bobbin winder cs-100
Nov 27, 2011 | Brother CS-100-T Computerized Sewing...
Brother CS80 ..... bobbin winder not working. power not being transfered to the shaft that turns the bobbin. how can i fix it?
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
Aug 03, 2011 | Brother CS-80
Exterior Bobbin winder does not turn or wind a bobin? Model CS-8072
you will need to turn the speed to maxium then press the start button. I attached a site that has your manual and shows great pictures of how to wind a bobbin.
brother model CS-8072
Mar 15, 2011 | Brother Sewing Machines
Cs 80 brother sewing machine manual hand book no cost downloading
Sep 05, 2010 | Brother CS-80
Brother CS-80 Logo
44 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
