Question about Samsung HCM4215W 42" Rear Projection Television
Is my samsung hcm4215W tv digital ready? does it have a digital tuner?
No it does not
Posted on May 12, 2010
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Is my Samsung TV model code LE32A456C2DXXU ready for digital?
Hello, jeanfbaker.
LE32A456C2DXXU is ready for digital ? answer is yes it is HD ready, its means support 1366 x 768 maximum resolutions, means capable of displaying high difinations (PS3, HD box) . And capabel a digital tuner , means capable receiving digital channels.
Apr 06, 2011 | Samsung Televison & Video
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
It is digital (HD), I don't need converter?
If your set is labeled as "HD ready" then it will accept HD signals from, for example, an external HD tuner or other source. The set can be HD Ready, as is my Samsung TV, but my set has only the older NTSC type tuner. I therefore use a digital stream HD tuner which works great to receive over the air signals. Also digital does not mean a set is HD. There are sets that are standard definition digital sets that can receive digital signals, but do not produce HD. If you are using cable, in most cases, you can continue receiving your cable as usual.
Nov 25, 2009 | Toshiba 36A40 36" TV
Do I need a digital converter for my Samsung LN-R268W TV?
If you are refering to signal you receceive on an antenna, then yes. It's actually called a Digital Tuner. The standard analog tuners that are in most older TV's will work for the Analog signals that you will probibally still be receiving, the Digital signals will not be available to you. This will depend on if stations in your area are at transmitting in Digital or analog or both. These boxes are the devices the government was either giving away, or making availalbe for a low cost to those whom need it via cupons. This has ended, but you can check this gov site out that talks in detail about it. You can buy the Digital Tuner boxes for pretty cheap from what I havce seen, but you will probibally need an antenna also.
Oct 25, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
Is it ready for the digital switchover
Hi my name is Eric,
I hope I can help you with your issue ,
Your TV would need a seperate tuner box if you are using an antenna. If using cable it just doesn't matter because digital signals received on cable can be recieved by any TV.
You can use a DVD/VCR that has a Digital ATSC tuner
see here it says HDTV-Ready - Requires separate receiver to view HDTV signals.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 28, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung hcm4215w tv Power,picture, sound problems
Replace the proscan module BP95-0007A Call Encompass Electronics for price 1-800-638-3328 or look for one one E-Bay Thats if TV comes on plays then starts shuting off/on If not replace power supply board.BP96-
Sep 10, 2009 | Samsung HCM4215W 42" Rear Projection...
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
I'm Told The Red Gun Is Bad On My Samsung HCM4215W TV
Im Sorry to say the red gun is sealed in to the crt not a lot can be done. Time to get a new TV.
Nov 16, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
138 people viewed this question
Jerry Greenberg
Jerry Greenberg
