Question about Zeiss CARL Visucam PRO NM Fundus Camera
I have a VISUCAM NM/FA fundus camera. It is very hard to move the base of the camera. Is there a way to clean it so it can move more freely?
I purchased a used Nikon FA camera for my daughter to use in her photography class. None of the pictures came out during developing. Any ideas what the problem could be? I was only given a 7 day return...
If it's still within the 7 days take it back. The Nikon FA was a great camera but time and lack of use has probably caused the shutter to seize. To put this camera back into serviceable condition for any photography will require a clean, lubrication and adjustment by a qualified camera person. I'm in Canada and have cameras service fairly regularly older ones to have this type of work performed will cost about $120.00 Canadian. The instructor is probably asking for the students to have a manual camera to be able to learn from the ground up which to me is the best way but, these old cameras are failing just because the grease is drying out. There are still a lot of good used working camera out there I just bought a great Canon Elan 7Ne for $199.00 CDN and it's a 2005 model the last year of the Canon film cameras. I guess it depends on if you want to spend the money (and time) to get the FA repaired or step into something for a little more money that works properly right from the get go.
Jan 24, 2011 | Nikon FA 35mm SLR Camera
Nikon FA depth of field preview lever sticky
The small lever on the inside of the mirror box is what controls the aperture. If the lever on the outside is sticking, it would only hold the lever on the inside down so you would be stopped down all the time. You can try a small amount of lighter fluid at the base of the outside lever and work it back and forth to see if it would free up.
Jan 19, 2010 | Nikon FA 35mm SLR Camera
Occasionally, when I mount any of my lenses and turn the camera on, the Av indication has no value and goes flashing, the auto-focus is dead, the shutter will not function. The problem gets solved if I...
If your lens fails to extend or retract, try cleaning it with a lint-free cloth and some lens solution. If it still won't move, try resetting it. Many cameras have reset buttons that restore the camera to the default factory settings.
this is a very general help i can provide you.
hope this helps you
Dec 29, 2009 | Pentax Normal SMCP-FA 50mm f/1.4 Autofocus...
Nikon Fa advance lever loose. Not used camera for a few years and set to M250 mode due to not having batteries, Advanced lever once to test, advanced one, then pulled lever back for another test. Lever...
Try moving the coupler on the bottom where the motor drive would connect. See if you can rotate the piece clockwise. With the advance lever loose, it may be in mid-cycle on the winding/advance
Dec 10, 2009 | Nikon FA 35mm SLR Camera
My KitchenAid washer will agitate, but the upper agitator assembly is not turning and I hear what sounds like marbles moving/slipping. Can I take that top piece off to look at it?
Based on your description, the problem is likely the self-rising tube that comes from the base (bottom) water feed tube. It may not be rising to engage the top assembly....
If it fails to rise all the way, the water will just spray into and on it and cause it to wobble versus rotate.
Pull up on the bottom feed tube - just to confirm that it will move freely...... (food, soap scum and age can prevent it from moving freely.) Clean and retry the washer.....
Nov 07, 2009 | KitchenAid KAWS700L Top Load Washer
Some keys of FA 260 are stiff and hard to press. It is difficult to enter some of the numbers.
I assume that its a keypad?, try something like rp7 or something that won't leave a gummy residue when it drys, get a hold of cotton buds or similar and clean around the edges of the pads if possible. It'll be crud buildup over a period of time most likely.
Oct 03, 2009 | Home Security
My pontiac grand ams shifter is hard to put in park
replace the shift cable remove it and see if it moves freely if not replace if it moves freely check the shift mecanisim on the tranny if it moves freely then the problem is the shifter... take it apart clean it and reassemble.. this should do it...
Jun 30, 2009 | 2004 Pontiac Grand Am
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Nikon FA will not advance. Meter will not give reading.
the capacitor is bad or the circut has a fault somewhere. You will need to take it to a camera tech or just use it in the manual moide only
Jan 14, 2009 | Nikon FA 35mm SLR Camera
Zeiss CARL Visucam PRO NM Fundus Camera Logo
78 people viewed this question
Top Zeiss Science & Laboratory Experts
William McMath
ray gallant
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
