Question about Boating
Bottom line manual
How do i switch the bottom line 1101 on
3 Suggested Answers
SOURCE: Bottom Line Tournament 1101
You can get a manual free by calling 1-800-456-5432. The Bottom Line Tournament 1101 is made by Hummingbird. I got the number from a sport shop here in Roseburg, OR. Called it and they're sending me the manual free! Good luck. -- Gary
Posted on Sep 05, 2009
aloha27
  • 693 Answers
SOURCE: Owners Manual
I've heard that Humminbird will be happy to send you a manual, just fill out the contact form supplied here:
http://www.humminbird.com/support/faq.aspx?ask=yes
Posted on May 01, 2010
How can onr tell if timer on Tork 1101 is not working?
Is the dial rotating?
1) Copy following link for Tork 1101 product wiring and manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
2) Tork 1101 120Volt timer uses #101 clock motor.
If clock motor is working, then dial rotates around clockwise once each 24 hours... assuming timer is wired correctly.
3) Jan 2013, Add a comment and say what you are wiring.
Jan 30, 2013 | Hardware & Accessories
I have a Tork 1101 timer and up until now has worked fine. Now it won't shut off. The mechanical on/off tabs are set correctly. It turns on and as the timing wheel comes around, the shut off tab...
If clock is rotating on time, next suspect is P47 trippers have worn down. Trippers are made of softer metal so they wear down instead wearing down the on-off lever, and that way the timer lasts longer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
New replacement Tork 1101 120Volt timer can be purchased on-line at Amazon etc.
Home Depot sells the 120V GE 15306 indoor-outdoor version of Tork 1101 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Replacement timer in Intermatic is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jul 24, 2011 | Kitchen Ranges
Hello can i get the instuctions for tork timer model 1191 please?
According to Intermatic conversion chart, Tork 1191 is same as Tork 1101.
Link to 1101 .pdf
Link to Tork manuals
Tork 1101 is dial-type mechanical timer. Dark pins turn OFF. Light pins turn ON.
Clock motor is 120V
Hot black wire from breaker connects to pole L
Neutral white wire from breaker connects to pole X
Removable bridge connects poles L &1 together
If bridge is gone, Hot from breaker must also connect to pole 1
Black wire to Load connects to pole 2
White wire to Load connects to pole X
Timer can control 240V Load if removable bridge between poles L and 1 is taken out.
Timer clock is still 120V: so 120V Hot still connects to pole L and neutral from breaker connect to poles X
240 V circuit has two hot lines: Hot line 1 and Hot line 2
240 volt Hot line 1 from breaker connects to pole 1
240 volt Hot line 1 to load connects to pole 2
240V Hot line 2 goes directly to Load and does not connect to any pole
Oct 04, 2010 | Hardware & Accessories
Owners Manual
Apr 29, 2010 | Bottom Line Fishin' Buddy 1101 GPS...
Owner manual and user guide
I do not have an owner manual would like to get one
Jun 05, 2009 | Bottom Line Fishin' Buddy 1101 GPS...
Mar 24, 2009 | Bottom Line Fishin' Buddy 1101 GPS...
Error code E
you may need a new transducer put on it like mine .mine had error 3 show up all the time. good luck
Jan 20, 2009 | Bottom Line Fishin' Buddy 1101 GPS...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
