Question about Gateway 6510GZ Notebook
Gateway ml6232 wont power on with battery or ac adapter help
I have a gateway ml6232 that wont power on
    President:
  • 987 Answers
Remove the battery then connect the adapter and try to power on...
Posted on Jun 19, 2009
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
My power button on my Gateway ML6232 is loose
Keyboard/Hinge Cover with Power Button Bezel,
http://www.laptopswer.net/products.php/GATEWAY_ML6000-MT6000_POWER-BUTTON_3CMA7KBTA07/cPath,1_97_102/language,en_US/osCsid,8d147ed2c28ef93651edc40940d868e7
The Power On switch is not part of this small cover. The Power On button that you see, is merely a little button cover. The actual switch is under it, and mounted to the laptop.
[ The Power On switch is a Momentary Contact Switch.
Much like this example of an ATX power on switch,
http://www.directron.com/atxswitch.html ]
Removal and Replacement of the Hinge Cover with Power On bezel:
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) This strip cover pops up. It has small plastic protrusions, or tabs molded on the outside edges.
These tabs snap into place in the Palm Rest Cover.
I use a small flat tip Jewelers screwdriver, and ease up on the end opposite of the Power On button. Then carefully go along the edges.
Replacement is to just line it up, and snap back into place.
Regards,
joecoolvette
Jan 14, 2012 | Computers & Internet
It wont charge therefore wont turn on if you can help me please do or give me an estimate price to fix it
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 14, 2011 | Gateway M-6319 Notebook
I got a new battery it worked when i got it now it wont charge ac adapter works though after i made sure the battery worked i put the computer away for a present for my daughter i have my own laptop so the...
Welcome to FixYa!
Jul 17, 2011 | Gateway T-6321 PC Notebook
I just purchased a power cord for my gateway ml6232 and I left it plugged in for 2 days and I have no power. Is there anyway to tell if the battery is junk before spending the money for a new one?
You need to get a new battery i had the same problem for my laptop and it turned out that there is no real way to tell unless your battery is leaking battery acid
sorry i couldnt be much of a help and good luck!!
Jul 17, 2010 | Gateway 6510GZ Notebook
6510GZ PC Notebook: gateway ml6232 want power up no lights...
Can be a lot of things.
Try with removing battery for 10s.
If that doesn't work, access RAM, remove it and install it again.
May 18, 2010 | Gateway 6510GZ Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Gateway MX6428 Power Problem
faulty wiring in the wall (hopefully not) or the AC adapter try another adapter or outlet
Aug 12, 2009 | Gateway MX6428 Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Gateway 6510GZ Notebook Logo
307 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
