Question about RCA Lands Phones
Can ATT unified messaging send a notice to my RCA 25423/24 phone?
The RCA phone has "New Msg" light that will blink if a message is waiting but it isn't working with ATT unified messaging.
JMuskovitz
  • 135 Answers
SOURCE: Continuous flashing of Msg/Calls light on my office telephone
Have you tried plugging a different (ordinary)phone in to see what happens? It is possible that either your phone line or your voicemail system is misconfigured. If it helps, here is a link to the phone's manual: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000043098.pdf
Posted on Apr 17, 2007
techman
  • 3130 Answers
SOURCE: Message Light
The only thing you can do is unplug the unit from the wall and from the phone line. wait over night and see if this resets the unit. if it does not, I,m afraid there is a circuit problem in the phone and most likely will not be worth repairing, but try to hard reset like I said first. good luck
Posted on Jun 11, 2007
jncayo
  • 31 Answers
SOURCE: msg button flashing
go to the phone where the light is flashing press intercom #409. you may have to do that more than once. Keep doing it until the light goes out.
If the phone system is a DK 8 orDk16 press intercom 409 this will cancel the message waiting light that could have been cativated by a different extension.
Posted on Oct 11, 2008
SOURCE: visual message waiting indicator
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Posted on Dec 20, 2008
consultel1
  • 860 Answers
SOURCE: Strata 3010 msg light won't turn off
To manually turn off the message waiting light press your extension button then press #409. Do this step for each message received.
Posted on Mar 25, 2009
Replace batteries for the RCA ViSYS 25424RE1-A
Your message file may be full. Try deleting your messages.
Sep 13, 2012 | RCA ViSYS 2-Line Speakerphone
Message Light
Jun 11, 2007 | RCA 25414RE3 Corded Phone
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
Light won't flash when a message is waiting.
New phone/cable provider corrected the problem on their end. Evreything works at this time.
Jun 10, 2009 | GE Lands Phones
BlackJack2 - can't sen d text msg
Call Att they will be able to help you fix this issue
May 05, 2009 | Samsung BlackJack II Smartphone
Mar 25, 2009 | Toshiba DKT 3010 Corded Phone
Msg. Light
Did you change carriers lately? Some new services include carrier's voicemail and they sent a signal to turn on your systems light. Check with your carrier firs.
Mar 19, 2009 | RCA 25423RE1 Phone
RCA 25414 message light... doesn't
I have 6 of these phones. No problem for a year or so, then one phone got the message light stuck on. Tried some online suggestions without success. Powering down etc. failed to fix it so I stuck a piece of tape over the led.
A couple of weeks ago line 2 failed (externally) and ATT sent a tech out who repaired it and also cleaned up the line. When the line came back, all 6 phones had the message light stuck on!
Talked with the tech here and with the ATT support and nothing worked. Eventually the tech here left as it was not a line fault - but he said he would leave the problem open.
That evening a young ATT guy called. He tried a number of different settings and changes - he was really determined! He called Kentucky and Minnesota and part of the advice was "give up and don't call the customer back"!
Finally he found a configuration option in the central office switch (exchange) for the line called CWMI (Call Waiting Message Indicator). Apparently this option was originally active but was changed when the local trunk was upgraded to fibre over the last year or so.
Once he enabled this option (we have call waiting and caller ID on call waiting on this line), the message lights on all the phones turned off and have worked normally since (10 days), including the one that was "broken" for over a year!
I really credit the tech with persistance on the issue.
Hope this helps someone else out there.
Regards, Hugh
Jul 03, 2008 | RCA 25414RE3 Corded Phone
New Message Light won't stop flashing
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
Jun 02, 2008 | RCA 25414RE3 Corded Phone
Msg light
I need more information. Your phone can be connected to one of many different Toshiba phone systems and you can also have different voice mail systems. I'm assuming you are talking about voice mail messages.
Can you verify that this is happening only on your phone? If you swap phones with another station does the light start to work? It's rare, but the light itself may be the problem.
Does this same thing happen to anyone else? Is the voice mail not turning on any message waiting lights? or is it working for others?
Not knowing all the details, you could try emptying all messages including saved messages. Then try to leave yourself a test message.
If you know how, you could have your mailbox deleted and re-created. This would need administrative rights to voice mail programming.
Most voice mails have an option to activate the MSG light or not when a new message arrives. Your's could have been turned off by mistake or glitch.
Nov 13, 2007 | Toshiba DKT-2020 Corded Phone
Lands Phones Logo
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
