Unit keeps flashing on and off - Computers & Internet
Why is my samsung printer saying prepare new image unit?
Imaging unit has a cerain page life and printer has finished those pages and is warning u to arrange for the same.
Aug 19, 2014 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
My unit flashes "fan check" and keeps shutting itself off
try to plug it off then look at back and try to blow to your fun or try to spin it with something a bit and plug in it back it should work and do not keep your fun to close to wall or cables
Mar 30, 2014 | Samsung Televison & Video
I have Garmin nuvi 1300 GPS it keeps restarting. I've read that master reset can fix this problem. but how can I save all folders before restarting ?
a rebooting unit will most likely not be resolved by a reset. The problem is usually caused by a failed firmware or map upgrade. When the unit boots and can not find certain files or they are corrupted, the unit crashes. The unit must be flashed with a service firmware to gain access to the units flash drive so that the corrupted files can be replaced. Once access to the flash drive is obtained, the favorites can be backed up as well. Once the files are restored, then the unit can be flashed again with the factory standard firmware. More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Mar 29, 2013 | Garmin nuvi 350 GPS Receiver
Receiver will not operate. when powered on red light flashes, menu displays, than thee is a loud click and the red light keeps flashing. tried the reset and it still does not work.
This sounds like the unit is going in to protect mode. See the link below for further information. Specifically to your unit, we need to know the model number. Also, try disconnecting the speaker cables completely and try again. Update this with how the unit reacts. If the unit powers up fine, then there is a problem with either the wiring to the speakers or the speakers themselves.
Please keep us posted.
Thanks,
Dan
Jun 17, 2011 | Denon Audio Players & Recorders
The green auto light keeps flashing on the head unit of my a/c and i can not turn the unit on. It has power, it does work, every now and then the green auto led stops flashing and i can use the unit with...
Need model and make of unit? Take off the bottom door of your furnace and there will be a label on the inside or the outside of the door it will tell you what the flashed mean.
Nov 25, 2010 | Heating & Cooling
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
My new TV keeps turning off and then on again with flashing red and green lights in front.
Check your warranty for the unit. Then call Samsung to see I they can help.
800-243-0000 Customer Support
If no help there repost with model # of the unit.
May 15, 2009 | Televison & Video
Unit will not turn off when OFF button is pushed.
I followed the instruction on how to reset the computer components, but the unit keep flashing Normal, Bypass and Phantom. The clock was flashing, so I resent the clock, and the flashing back and forth stopped. I just tried it again to be sure it was still working properly and it is!
Jan 28, 2009 | Sharp Multi-System Mini Component System...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
