Question about Ocean Technology Systems OTS Interspiro AGA MKII FFM & Buddy Phone Package
Corroded battery terminals
How to replace them
My 2007 hyundai santa fei has just went completely dead....battery is fine....I've been told it could be a faulty earth but I have checked all earth's and cleaned them and re tightened them?
Completely dead is usually:
a corroded battery cable near the connectors, -cut off corroded end & refasten or replace cable.
a loose or in adequately tightened terminal connector, -replace terminal or cable
bolt off starter motor, -replace or repair bolt.
battery plates out of alignment, -replace battery tray \, hold downs & battery.
A blown fuse is rarely the problem.
Good luck.
Aug 15, 2015 | Hyundai Cars & Trucks
Try to start and it clicks
Low battery power = Charge battery.
Dirty or corroded contact at terminals = Clean and tighten all terminals.
Bad contacts in starter solenoid = Clean contacts or replace solenoid.
Battery to starter, cable corroded or damaged = Replace cable.
May 27, 2015 | Cars & Trucks
Ford tuarus has no power. Nothing turns on including ignition. Could it be bad or corroded battery cable?
Yes it can be; or it could be that the battery is dead (or bad).
Disconnect the cables, clean the battery terminals, clean the inside of the cable ends. Connect a battery charger, let it charge for at least an hour (don't just use jumper cables from another car). Once charged try it. If you still get nothing, it could be that the battery is shot. In that case, replace it.
Jul 31, 2014 | Cars & Trucks
Corroded terminal assembly 1999 rav
all part stores have the battery terminals ,and they are easy to replace
Dec 13, 2012 | 1999 Toyota RAV4
I am trying to replace the battery for a '97 Suzuki Sidekick. The battery terminals were so corroded, I had to cut the wire and put on some universal terminals. There are two wires for each terminal-
This happens in the shop all the time. It is not necessary to remove the alarm if you have the remote for the alarm. Simply hook the battery up and press the button to turn the alarm off.
Nov 23, 2011 | 1997 Suzuki Sidekick
Battery cable kroded car want start how can i get it to start
well for starters if the cable is corroded you will need to measure the cable and replace the cable, autozone has many options for you with cable replacements.
If in fact you battery terminals are corroded and they can easily be replaced on hondas i believe you just have to cut the cable right next to terminal and replace them with new ones this is also very simple and cheap (2.49 ) per terminal at autozone.
all you do to replace them is cut the old one off the new ones you will just bolt a metal plate over the wire
If its the battery post just go buy a battery cleaning brush cheap to and clean the post and the terminals and you will be ok. May i also suggest that you put felt washers and battery terminal grease to prevent re corrosion of the above items.
also clean the post terminals and it should start you just don't have a good electrical contact
Hey if it helps how about a 4 thumbs up thanks
May 15, 2011 | 2006 Honda Accord
I can't get the positive battery terminal cable off of the old battery because it is too corroded. So, I would like to replace both terminal cables and the battery. The problem is there is a wiring harness...
Best would be to wet the battery terminals with water, take a sponge and place it on the battery terminals which are corroded and pour water to it, let it stay a while and again pour some water to the sponge, you will note tht the corrosion will start to fade away and thus you will be able to remove the battery terminals kinda easily!.
Hope this helps!
Nov 30, 2009 | 1996 Oldsmobile Cutlass Ciera
Alarm says terminals corroded
One of two things:
Somewhere in the wiring you have a weak connection and it is interpreting it as a bad battery or corroded terminals. It could even be where the cord goes into the sump pump. You will have to search it completely to find it.
The alarm itself is bad.
May 25, 2009 | Ace Hardware Ace& Battery Back-Up Sump...
Internal battery terminal corroded and fell off
Old batteries leak and the battery terminals corrode. Replace the terminals and clean the area thoroughly.
Jul 27, 2017 | Canon Optics
Ocean Technology Systems OTS Interspiro AGA MKII FFM & Buddy Phone Package Logo
48 people viewed this question
Top Ocean Technology Systems Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ocean Technology Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
