Question about Cobatco MD-10SSE 8 1/4" Waffle Cone Baker
How to turn down the temperature? - Cobatco MD-10SSE 8 1/4" Waffle Cone Baker
Temperature control in fridge is turned all the way down but still too cold-25*, freezer=10*. What can i do? Amana SZD27ME side by side
Turning down the dial is not recommended as it does not turn the temperature down. Please return it the factory setting. If your temperature is too cold in the fridge, it may be the timer or thermostat. If it its in the freezer, it's the thermostat. If it both, you have a bigger problem, such as the compressor may be malfunctioning.
Jan 13, 2015 | Amana Refrigerators
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How do I turn my thermostat down?
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
May 09, 2014 | Ouellet Heating & Cooling
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Turn temperature down
Any less than 15C is considered dangerous to the health and may cause chest problems.
Dec 11, 2013 | Computers & Internet
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
My Haier compact refrigerator won't turn on
A new thermostat is required. When you turned it down you probably broke the contact and will not re-connect. Be careful installing the new one the fine tube contains gas which is temperature sensitive. do kink or break it.
Apr 17, 2010 | Dometic WA3210 Compact Refrigerator
Why when i turn off my 99 XLT explorer the temperature does not goes down
The temperature will go down if the vehicle is not running but the guage will stay until you turn the key back on as long as the engine has had time to cool down.
Feb 25, 2010 | 1999 Ford Explorer
Boiler making clicking noise
contact baxi and ask ther service people there was aproblem with this but i cannot recall it now ,hopethis helps
Jan 09, 2010 | Heating & Cooling
Cobatco MD-10SSE 8 1/4" Waffle Cone Baker Logo
54 people viewed this question
Top Cobatco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Cobatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
