Question about GPS
My GPS receiver cannot switch on. The battery is fully charged. When i press the ON button, it keeps blinking searching for satellite but when i release the button, it will turned off. what should i do?
  • syanaf Jun 19, 2009
    I already check with voltage meter and the output is too low. but when i charge it, it will goes off by 5 minutes. seems like the battery is fully charged. now it cannot switch ON at all.
  • syanaf Jul 10, 2009
    Its not over charged. It seems to be ON all the time. I checked with voltage meter and the reading is really low. I just bought it around 4 months ago from ebay UK. and its hard for me to return it back as i live far away from UK. maybe im not lucky enough..
It could be over charged. You can either leave it in the GPS for several days, or find out the voltage and hook up the corresponding number of light bulbs (Flashlight or LEDs) to drain it. If you have a voltage meter try checking the volts and amps being output, this should match your batteries specifications.
Posted on Jun 19, 2009
  • vbot808 Jun 21, 2009
    I don't suppose it's still under warranty? Sounds like a circuit problem.
The led keeps on blinking and don,t load the battery
Hello there,
If the led light on your gps heeps blinking, then it simply means there is not enough power to start it up for you. Please ensure the battery is fully charged before you try to power it on. Also be sure that the battery is holding a charge by trying it out on another device and charging it there. Ensure also that your charger is also working.
Hope this helps. Goodluck Elect_Comp
Sep 02, 2011 | SNK CarTrek 400 Car GPS Receiver
Our tomtom one gps does not receive signals and becomes dead often.
Bad connection on the power supply may be the problem and this will not allow the unit to charge fully. Bad battery time for a replacement battery. No satellite? Try moving the unit down towards the defroster vents and keep it so that it is close to the front windshield. If these units do not have a clear view of the sky they will never find the satellite and you will always be frustrated with it. Hope this helps
Jun 15, 2010 | Tomtom ONE GPS Receiver
It shows a car with a flashing question mark and says on the top: searching for satellite. What should I do?
1) make sure the battery is fully charged
2) place the unit where iut has a clear view of the sky
The most common delay in connecting is low battery power.
If you have connected DC when staring engine you may have damaged the SIIRF chip and it will never find the satellites.
Try charging the battery fully as your first step
Aug 18, 2009 | Garmin Nuvi 660 GPS Receiver
60CSx switches automatically off directly after connect
Go to Main Menu by pressing MENU button twice. Choose SYSTEM and press ENTER. You can change various settings on this page. Make sure that for GPS option 'Normal' is selected. If it is set to 'Battery Saver Mode' the GPS will switch off after certain time.
Jul 07, 2009 | Garmin GPSMAP 60CSx GPS Receiver
No signal at all.
make sure the battery is fully charged its searching mode and the battery on GPS may be too low
also make sure you are operating in an area the gps internal arial can see the sky
Jun 22, 2009 | Mitac Mio C310 GPS Receiver
My 300 Tom-Tom quit on me. No screen or anything. Help!!
Plug it into your computer using a USB cable and press the reset button. Once it resets, keep it plugged in and your computer turned on, until the battery is fully charged. Every so often, charge it. If the battery goes totally dead, it will create problems.
Mar 19, 2009 | Tomtom GO 300 GPS Receiver
Garmin zumo 550 cannot find satellites
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Jun 16, 2008 | Garmin zumo 550 GPS Receiver
No power to my ICN 520
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Jun 08, 2008 | Navman iCN 520 GPS Receiver
GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Jan 02, 2008 | Garmin 60 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
GPS Logo
105 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
