Question about Dell 1130 Laser Printer
Dell 1130 grinding noise - Dell 1130 Laser Printer
What causes a loud grinding noise when I print?
Howell310,
Can you provide the model of the Dell Printer you have that is making a loud grinding noise. I can the search for resolutions to this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 27, 2016 | Dell Office Equipment & Supplies
I cant print right side binding booklet
Coimbatoreamil Aamil,
You can click the link below to download the online manual. View the portion of the booklet that refers to printing booklets.
http://www.dell.com/support/home/us/en/19/product-support/product/dell-1130/manuals
Thank You,
Dell-Jesse L
Jun 07, 2015 | Dell 1130 Laser Printer
Grinding noise when printing
If you have replaced a toner cartridge recently, eject the cartridge again and reseat it correctly.
Apr 25, 2014 | Dell Office Equipment & Supplies
Grinding noise
I just chatted with Dell support about this since I have the same problem of the grinding noise on my C1760NW Dell printer. I have it plugged into an APC backup battery which acts like surge protector (unless power goes out then battery kicks in). He said the printer needs more power and that surge protectors and battery backups are not good for this printer since they restrict the power which sends less power to the motor and fuser than what it was designed for. So with less power from the APC backup/surge protector, the motor moves very slow and may not fuser the toner to the page correctly and can cause permanent damage over time. So I plugged into the wall directly instead and the grinding noise went away immediately even when printing 10-15 pages right after plugging into wall, but then the noise came back when I printed a bigger job. So for now I'm letting it cool down for a couple hours and crossing my fingers that the damage is not permanent. So... answer is plug it into the wall directly for maximum power and hope that your printer is not permanently damaged. By the well, Dell support chat was awesome.
Mar 11, 2014 | Dell, Inc Dell Color Printer C1760nw -...
Can't get dell 1130 printer to work
Solution For Samsung Printer scx-4300 ml-1640 ml-3310nd scx-4521f
catridge reset solution contact-09040653885 navanath meher
Feb 01, 2014 | Dell 1130 Laser Printer
Solid red light dell 1130
MY DELL 1133 PRINTER PROBLEM END OF LIFE IN CARTRIDGE
HOW TO SOLVE IT PROBLEM PLZ REPLY
ISMAIL
VISAKHAPATNAM
May 15, 2013 | Dell 1130 Laser Printer
There is a red flash light on a control panel. What to do?
The toner is nearing the end of its life. You will notice printing may become faded. Replace the toner cartridge and the red light should go away.
Mar 02, 2011 | Dell 1130 Laser Printer
Disc drive noise
maybe the drive is defective. try using a usb drive then test.
Apr 08, 2010 | Dell Studio 1537 Laptop
Potscubber 1130 making grinding noise?
ck chopper may need to clean internal parts
Feb 04, 2010 | GE Dishwashers
Dell 1130 Laser Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
