Question about Dell MO56OUA 2-Button Usb Optical Scroll Mouse P/N: MO56OUA - Ori
Driver mouse the mouse no regconozied for windows xp sp3
I am not able to get BAFO BF810 to get working on Windows XP SP3 - dont they have drivers for SP3? It works on SP2 though.
here is a linkt to the BAFO support site the drivers listed for your USB serial adapter the driver is listed for XP, Vista and Windows 7. As SP3 came out before Windows 7 I think the driver will be compatible with XP SP3
here is the link to the driver download
http://www.bafo.com/download/Driver/PC/BF-810%20DriverInstaller_v1210_windows.rar
Feb 24, 2011 | Office Equipment & Supplies
Need drivers for windows xp pro 64
The XP driver is available at:
http://support.visioneer.com/products/8700/downloads.asp
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
Mar 25, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
Touch pad mouse will not move
There will be a button above the touch pad or using function key to disable it. try both and find out which is the prob. Some drivers may not installed properly. Run the touchpad driver in administrator mode and if you are having the xp driver set to xp sp3 compatible mode.
Jan 13, 2010 | Computers & Internet
Windows XP Pro SP3 will not boot normal mode
This may be because you have the wrong drivers installed- i reccomend starting your computer up in safe mode and using system restore go back to a past restore point before upgrading to SP3
then update your drivers before upgrading to SP3
i reccomend drivermax.com to update drivers.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Microsoft Windows XP Professional SP3 Full...
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
Mouse Not Working in XP
the very first thing what u have to do is uninstall and reinstall the driver for the wireless mouse and then restart the computer and still if it doesnt work try it with some other computer which has xp sp3 and it it works with the other computer have the same windows os then uninstall and reinstall the wireless driver also,and if it doesnt work with the other computer also then replace the wireless mouse.but before that always check ur wireless connection with the wireles mouse and also check the lights on the mouse..and what u can do is call up dell and tell thatm to replace it for u or for complete solution u can call up cyyberdefender.com for premium tech support.......take care ...
Jan 23, 2009 | Microsoft Wireless Optical Mouse
Scrolling Problem Following Windows SP3 Installation
This is obviously a driver fault, unless by coincidence the mouse is failing.
For a start, try uninstalling the driver, and then re-installing it back.
Jerry G.
May 25, 2008 | Logitech Marble Mouse PS2/USB MSLO904360
Dell MO56OUA 2-Button Usb Optical Scroll Mouse P/N: MO56OUA - Ori Logo
29 people viewed this question
Alun Cox
