Question about Refrigerators
Is there a water routing diagram for refrigerator Mod #WRF560SEYBOO?
I had disconnected the solenoid valves from the refrigerator to keep them from freezing in the winter.
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
tech master
  • 120 Answers
SOURCE: Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
Posted on Oct 17, 2008
SOURCE: Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Posted on Feb 15, 2010
  • 36 Answers
SOURCE: Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Posted on Mar 05, 2010
machinetech7
  • 1344 Answers
SOURCE: What is the correct tubing diagram for frigidaire side by side refrigerator ice maker
http://www.youtube.com/watch?feature=player_embedded&v=1J3VDTbiAvA This should help you out. good luck.
Posted on Apr 29, 2012
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
My ice maker receives water after it has filled and frozen ice cube tray, water in door is a very weak stream, where do I find a correct water line routing diagram, already replaced water valve?
A plugged water filter will cause low flow. To identify which solenoid operates the water flow on the door have a helper operate it while you feel for which one is working. It's possible you crossed the lines. That would explain water running over frozen ice cubes.
Aug 29, 2017 | Refrigerators
My Refrigerator has not made ice since house water was turned off for 3 hours and turned back on, how can i fix?
disconnect (or turn off) the freezer; also disconnect water supply. Keep that for a day to unfreeze water pipes inside then reconnect.
Mar 30, 2015 | Refrigerators
Not water in the door
For a 1993 model, the problem is most likely a clogged inlet strainer on the solenoid operated valve on the back side of the access cardboard cover near the bottom of your refrigerator. If you take your model number to Searspartsdirect.com and you can order a new valve if the solenoid has finally stopped working.
Before to much troubleshooting, check the isolation valve where the water hose hooks up is open. It may be someone closed the isolation valve.
Hope this helps
Dec 15, 2014 | Refrigerators
Ice maker not making ice. no water being dispensed
If you have water entering the back of the refrigerator - check to make sure it is connected and turned on. The water is routed to a reservoir and chilling tubes. It then goes through a two line solenoid controlled valve - one to the ice maker and one to the water dispenser. Since you aren't making ice or getting water - I would suspect the two line solenoid controlled valve.
Jun 17, 2011 | Refrigerators
I'm looking for an electrical schematic for the back bottom of a Whirlpool Gold Mod. GD5SHAXLB01. The wires are disconnected from the condenser fan, and there are other wires that are disconnected. We got...
Hello Purdida,
The only location I can find a wire diagram is at Sears Parts Direct and you have to schedule a service tech in order to get the wire diagram you may be able to talk to them in and get the diagram as you are ready have a tech available. Here is the link to the wire diagram http://www.searspartsdirect.com/partsdirect/part-number/Whirlpool-Parts/Refrigerator-Parts/2220104/0046/106/Model-GD5SHAXLB01/1198/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=GD5SHAXLB01&subCompDesc=Cabinet%20parts&brandDesc=WHIRLPOOL&modelDesc=SIDE-BY-SIDE-REFRIGERATOR&pathTaken=partSearch&blt=11
Sorry could not be of more assitance. Thank you for choosing FixYa.com
Justin
Apr 24, 2011 | Refrigerators
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker arm rolls up and down butice tray doesnt fill with water
Hi, check to make sure water supply o/k. if there's water present, first check water solenoid valve, pull out ref. and disconnect your water connection, look inside solenoid valve, clean any debris from it, connect water and try ice maker, if it didn't work, disconnect water and check water solenoid valve, that's devise, where you make, your water connection, remove two wire from it(coil) and check coil for continuity, check for resistance with ohm meter, sometimes they burnt out. good luck.
Aug 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser not working on Whirlpool mod ED25COXFW01
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the dispenser solenoid, or the whole dispenser assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 13, 2009 | Whirlpool ED5FHEXMQ Side by Side...
The solenoid on the water inlet valve leaks... need illustrated parts list so I can order proper parts assembly
you have the info rite / it is called the water inlet solinoid valve. this along with the mod. ser. # is all you nead to order the replacement valve. hope i was a help
Oct 20, 2008 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
