Question about Tablets & eReaders
My iview 755 tcp wont turn on.I have tried every suggested trick,no luck.Please help.
It was working fine,I turned it off for the night.It won't start.The battery is fully charged.I did the hard reset.I have no way to copy the firmware.
  • 24 Answers
SOURCE: does not turn on under battery power
Battery may be faulty, perhaps you can swap with another user to rule this out. Do the battery charge level lights on the back of the battery show a full charge? (Press the rounded square button on the back of the battery itself and note whether the 3 green leds light up or not) Has the battery been calibrated? (You will need the "toaster" style or the DT533A charger to do this). I assume that your battery is secure and properly seated, but try taping it down from the back side just to be sure it is snug. Don't use duct tape, just regular scotch style tape or blue masking tape. Also try laying on your back to hold the unit upside down and power it up. Check the small metal fins that mesh with the battery. They are right above the right side of the windows cert of auth sticker when turned as you would to read it. They are NOT all the same length, do not push or pull them, but if one is bent you may try to straighten it VERY carefully with very small tools.
What happens if you unplug while up and running?
How does the power jack feel when you insert or remove it? any looseness may indicate your trouble. A good tech can repair your trouble. Are you sure that you are not under warranty? HP still sells extended warranty for these machines. My original warranty expired in Sept and I bought extended warranty for another year. I'm in central MO if you are close by at all I would meet up and swap a batt for a minute for you. Also, you may get a lil more usability with a car cord if the problem cannot be resolved at all.
Best of luck! I love my tc1100 and the older brother tc1000 as well. I have several of each.
Posted on Apr 05, 2008
SOURCE: Q1 ultra not booting
Fixed it. Opened the back cover and reinserted the memory.and it bootedup. So I guess memory got loose.
Posted on Feb 18, 2009
  • 846 Answers
SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
  • 5 Answers
SOURCE: my literati wont turn on
Hm. Not sure how much help I'll be, but I'll give it a shot.
- Make sure the device is charged for at least 6 hours if this is its first use. If it isn't, charge it for several hours anyway and try it again. Make sure the charger is plugged all the way into the outlet and all the way into the device (mine sticks out about an eighth of an inch, yours might too). - Call customer service at 866-204-4714 and describe the issue. I had something a little like this issue (I was stuck at "Literati" screen) and they said to drain the battery and recharge it fully to see if it made any difference, and that if it didn't work they'll be sending along a package to ship it back to them for a replacement. If nothing works, ship it back to them for a replacement.
Posted on Feb 15, 2011
sayedmohu
  • 645 Answers
SOURCE: Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Posted on Oct 03, 2011
My tablet won't turn on
Atonio, Check the attached troubleshooting links for tablets not turning on,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Do When Your Android Phone or Tablet Wont Turn On
Help My tablet won turn on what do do
my android tablet wont turn on how to fix
Why Does My Android Phone or Tablet Not Turn On
Jun 30, 2016 | Tablets & eReaders
My tablet has always worked just fine an I left it in my car for about a week finally brout it in an charged it over night an it wont turn on at allis there a quick an easy way to fix it please help.
Most likely the battery has failed and will no longer hold a charge.
Some of these batteries will fail if they are run down and then left uncharged for more than 2-3 days.
Jan 13, 2016 | Tablets & eReaders
My tablet wont let me tuch anything
my suggestion would be to turn it off and unplug the power supply if it is plugged in.Wait 30 seconds plug it back in and restart the device.
Mar 01, 2014 | Iview Cyberpad 756TPC Tablet
Wifi and Bluetooth won't turn on my iview cyberpad
in settings underneath wireless and networking check to make sure that they are turned on also check to make sure it is not in airplane mode
Dec 27, 2013 | Iview Cyberpad 756TPC Tablet
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
Sep 24, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Wifi won 39 turn
you have to do is be root and install an app called root exploret
and go to system / app here find the application to be deleted and if you go back to the menu and restart the tablet is removed and you can download the update hope you reserve
Aug 31, 2013 | Iview Cyberpad 900TPC 9-Inch Tablet
Tablet wont turn on
Please help me to get my MiTraveler 10C3 OS: Android 4.0 fixed.
Jun 12, 2013 | Coby Kyros Internet Touchscreen Tablet...
Too many pattern attempts to unlock my iview 754tpc but my wi-fi was switched off so how do i sign back in
only by putting a sim card with a active data connection in the device then attempt to unlock, you can not remotely turn on wifi very easily, may be a bit more simple if you have debug mode turned on but most people don't-Good Luck.
Jan 27, 2013 | Iview 754TPC with WiFI 7" Dual Camera,...
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
