Question about Craftsman 6" Bench Grinder with Lamp
Bench craftsman diagram grinder wiring - Craftsman 6" Bench Grinder with Lamp
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Can you get a replacement? If not, we could probably figure out some suitable substitute.
Charlie
Posted on May 31, 2009
SOURCE: need manual or pdf for manual
I have the manual you are looking for
Posted on Jun 24, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Posted on Dec 28, 2009
Testimonial: "Great solution. Yhank you. - b"
  • 4088 Answers
SOURCE: How do you tighten the nuts when changing the
Clamp the shaft behind one wheel with 'Channelock' or 'Visegrip' pliers, then tighten both nuts. Check the new wheels for 'off-center' running by spinning them with your hand. They may fit the shaft tight enough that there is no centering adjustment--use a 'wheel dresser' (either a stone type or a multi-wheel type) to true up the wheel so that there is no radial wobble. Hope this helps!
Posted on Oct 23, 2010
SOURCE: i have a sears craftsman bench grinder 1/2 hp 5.1
hceck the belt driver ,it mite be broken
Posted on Apr 30, 2011
Looking to replace obsolete switch on Craftsman 1/2 hp bench grinder. Sears lists part as 4984992
This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
Dec 12, 2015 | Craftsman Grinders
Looking for a on/off switch for a craftsman 8" bench grinder
Sears Craftsman is usually easy as Sears Parts Direct has diagrams and part numbers.
However your switch number 31919063033 is no longer available. I would suggest checking out online places like Digikey or Newark for a switch that will work for you. As long as the Voltage, amperage and number of poles and will fit in the space provided you should be OK.
Link to Sears Parts Direct.
Searching Model For Search Your Way 31919063 2
Link to Newark
Switches Relays 60 674 Products Found
Link to Digikey
Electronic Components
Aug 19, 2014 | Craftsman Grinders
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Older sears bench grinder wont run 1/3 hp model 397 19581
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
May 31, 2009 | Craftsman 6" Bench Grinder with Lamp
Craftsman 6" Bench Grinder with Lamp Logo
207 people viewed this question
Top Craftsman Grinders Experts
Lawrence Oravetz
Vernon Taylor
ray gallant
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
