Question about 2005 Chevrolet C8500
I have a 2006 chevy c8500 all gagues work except speedometer and tachodmeter
2 Suggested Answers
  • 708 Answers
SOURCE: how to reset oil change light on a 2006 Chevy
IF it is in the radio and not a seperate computer then you do the following: Go into the vehicle settings with the radio controls. With the key turned to ACC, hold DISP on the radio for about 6 seconds and it should go into settings mode. Press DISP until you see oil life in all caps, then use Prev. & Next to scroll to reset oil life mon., then push DISP again. you should here a beep and the display should read Done. Scroll to Exit and press DISP again.
Posted on Oct 01, 2009
The speedometer on my 2004 Pontiac Montana quit working. Is there a fuse for that?
Nope. The speedometer needs a signal from the vehicle speed sensor to operate. Is the check engine light on? If so, scan for any codes that may indicate a VSS problem. If no codes, possible internal cluster issue with the speedometer head
Jan 27, 2016 | Pontiac Cars & Trucks
If my trans was unplugged will the speedometer quit working and trans quit shifting? 04 chevy 5.3 z71 vortech
YEP YOU NEED VSS SENSOR HOOKED UP SO TRANSMISSION CAN SHIFT RIGHT.AND SHIFT TO OVER DRIVE AT SET SPEED. YES YOU NEED TO SEE YOUR SPEED TO KEEP FROM GETTING A SPEED TICKET.DONT UNPLUG IT.
Feb 02, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
My 2006 kia spectra speedometer is not working wat cud be the problem
2006 kia spectra speedometer not working. Try this, I just did it and it worked. Disconnect both battery cables and touch them together for about 3 seconds, then connect them back to the battery. This causes the main computer to re-load all computer programs. It worked on my kia, speedometer now working. It also worked on my 2004 Chevy Silverado to correct an AC/Heating problem just after installing a new battery. The truck blew hot and cold air at same time with only AC on.
Sep 12, 2010 | 2006 Kia Spectra
How to reset oil change light on a 2006 Chevy Kodiak c8500 with Cat motor and Allison auto trans?
Sep 30, 2009 | 2006 Chevrolet Silverado 3500
No speedometer, gas gauge, temperature gauge, and
check your fues box were it say gagues
Jul 01, 2009 | 1989 Volvo 740
All warning lights flashing on dash of chevy trailblazer 2003. Runs fine all gagues go dark like truck is turned off but runs fine
All warning lights flashing on dash of my 2002 chevy trailblazer. Runs fine all gagues go dark and turn back on every now and then. Also the gagues all go to the right or stick half way like I am idling at 5000 and going at a speed of 60mph when I am sitting still. I am thinking it has something to do with my computer because the rest of the truck is working just fine.
May 18, 2009 | 2002 Chevrolet TrailBlazer
All gauges..gas,speedometer,temp,odometor...won't work.
the problem might be in the ignition switch(not where the key goes) but what the key switch is connected to. just try this first, when the gagues stop working, hit the steering column behind the key switch and if the gagues start working then replace the ignition switch
Mar 27, 2009 | 1997 Chrysler LHS
Gagues stopped working, even the digital readout, on my 2003 Chevy Suburban The wire harness is connected properly. Any ideas on how to fix this problem?
I'm going to assume you checked the fuses, and say that the display panel will have to be replaced. On these the display is all one piece, and when one gage goes out it effects the whole thing. Some of these display panels had in line fuses on the inside circuitry, so you may be able to pull the display and change the fuse. Others were built as a sealed unit and cannot be taken apart.
Aug 21, 2008 | 2003 Chevrolet Suburban 1500
Speedometer is not working isnt conected to the transmission
1993 toyota pickup 4wd 3.0l the odometer does not work, but the every gagues are working okay. need help!
Jul 28, 2008 | Toyota Pickup Cars & Trucks
2005 Chevrolet C8500 Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
