Question about Staples Arrow T2025 Staple Gun For Flat & Round Crown
How I can change the level of the staple arrow T2025
Replacing staples
On the back there is a small metal piece that is spring loaded push it in and down and that should release it pull it out and slide staples in replace assembly remembering to push in and up to reinstall holder .Hope this helps.
Bob
Jul 18, 2014 | Arrow Fastener T72 Wire & Cable Staple Gun
Changing height guide on arrow staple gun
Far as I know (and I own one) there is no height adjustment. It's preset to avoid damaging the cable.
May 30, 2011 | Arrow T25 Staple Gun
I cannot insert the retainer spring into the stapler 2025, with or without staples. What am I doing wrong? Arrow fastener model T2025. I played with the front piece for different sizes of staples; since...
make sure the rod inside the spring is not bent. the slightest bend can cause the retainer or push up loader to act goofy. Also make sure the u shaped(a square U) that makes contact with the staples isn't warped or out of shape. and if staple gun was ever dropped the whole track it slides down could be pinching down too much creating resistance. if so, pry open gently wherever you see that it might be getting tighter. If a visual inspection is not obvious try slowing sliding the spring loader into staple gun's staple track and once resistance is felt start to gently work open with a pair of needle nose pliers, insert closed the use two hands pull pliers open to spread the track apart. . Or any method you find easier that would create the same effect. be inventive and use commonsense always. before u know it you will be MacGyver. LOL Hope this helps, and good luck.
May 09, 2011 | Arrow T25 Staple Gun
Bought a "mont marte" handstapler and cannot find staples! 11.3 mm wide - 8 mm long and 1.2 mm fat! The last measurment is important, slimmer staples eject in two or threes in a twist! Can you help me?...
This is a stapler primarily for upholstering applications. Try inquiring at your local fabrics store or upholstering supply dealer. They may carry the staples. Unlikely you would find these at a hardware store but you could still try Lowes or Home Depot.
Oct 01, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Putting the nails inside the gun
Here is the manual http://www.arrowfastener.com/upload/manuals/79055020257_manual.pdf
Eric
Jan 24, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
How do I open the darn thing to add staples?
Thanks for the link to the manual, fixyajohn. However, it wasn't clear on how to open it. However, the manual gave me the clue that it was simpler than one would anticipate when you first start grabbing at it. Just push in on the flat panel on the rear of the stapler. That disengages a little hook from the slot in the body. Then pull the released assembly downwards and finally rearwards out of the channel. Very simple. techmag's answer just doesn't apply to the T2025.
Aug 20, 2009 | Staples Arrow T2025 Staple Gun For Flat &...
Staples Arrow T2025 Staple Gun For Flat & Round Crown Logo
44 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
