Question about Polaroid Tlac-02255 22" 1080p Hd Led Lcd Television
TV Won't turn on
I connected the TV to the cable but i only get black screen with no signal flying around. The cable works as i have another TV which was connected to the cable
Why is my tv jvc hd70zr7j showing a blank black screen when i connect the hdmi signal cable? the ps3 used to work fine before but since i moved into a new place it just shows the black screen
you have a HDMI port Failure that's not uncommon many people fail to turn the units off before switching cables around it only takes a momentary short on the 5 volt line to one of the other lines and it can short it . or it may just be a normal failure . but you would have to change the .with the AV and HDMI ports on it to restore operation . your set probably has more then one port ? have you tried the others . by process of elimination you have ruled out its the game and cables so it points back to the tv
Jan 07, 2015 | JVC HD-70ZR7J OEM TV Lamp
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
TEAC LCD191SD WIDE SCREEN LCD TV WHY NO SIGNAL
U have a signal word bound around or said no signal in ur LCD Screen?Than it ur colax cable not getting signal comming in.Try reset ur cable or satalite box by turning it off/on.IF the LCD screen totally black,try unplug,replug might get picture back.Not than must replaced the main video backlight board it dead must be replaced.
Oct 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No Signal from cable setting.
check settings on your source...make sure you are not plugging into a DVI/HDMI port on your TV unless you are in fact converting from DVI to HDMI (there a connector to buy) if thats not it replace the cable with a different one. There are several varities of HDMI cable and the signal is faster as you increase in price normally. I have Monster cables that work Perfectly....I would also check TV settings on the port you are plugging into and try a different one to see if the result is the same. If the result is the same you may have a bad source. Always rule out the cable too.
Feb 10, 2009 | Sony KP-51HW40 51" Rear Projection...
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Polaroid Tlac-02255 22" 1080p Hd Led Lcd Television Logo
32 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Mars Nspace
Mars Nspace
Level 1 Expert
Bill Boyd
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
