I can go to the master he always listens - Audio Players & Recorders
E2000 mazda tray top .weak fluid pressure from master ,fcylinder to caliper foot pedal does not pump up pressure enough to bleed caliper
Yes it could be a bad master cylinder. But always remember when bleeding brakes. No matter what component on the brake system was changed. You ALWAYS bleed all four wheels and rule #2 ALWAYS bleed from furthest from the master cylinder first and work your way to the master cylinder. This ensures you remove all the air from the break system and not just move the air back and forth inside the lines. Try that. Hope this helps.
Nov 28, 2012 | Mazda Cars & Trucks
Brake master cylinder location. Stiff brakes first thing in the morning
master cylinder is in the engine compartment on the firewall in front of the driver seat. Stiff brakes do not indicate a bad master cylinder, but could indicate the booster. Listen for vacuum leak at the booster with engine running. The booster is a big donut shaped thing behind the master cylinder.
Aug 29, 2010 | 2004 Chevrolet Aveo
I am not being able to connect internet by my samsung gtb3410 corby set havin vodafone line with the computer,please sujest a solution...
Vodafone always has he **** internet okay listen go on to your settings reset your fone but dont't master reset just reset it and turn it back on and try going on to the internet but if that does not work call your network vodafone tell them they will tell you to turnoff your phone for 5 minutes and they will refresh it themselves...
Jun 06, 2010 | Cell Phones
EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Oct 06, 2009 | LG enV3 VX9200 Cell Phone
Hi. i have a 2004 2.0 gt fsi and it sounds like a diesel
the FSI engine is a direct injection engine and they can be noisy particulaly on idle ,if you have no other issues like warning lights lack of power and its always been like it then i sugest it is the nature of the beast .this is not ******** i am a vw master tech and have had many a conversation with customers about noisy FSI engines.hope this puts your mind at rest,alternativly go to VW dealer and get them to take a listen to confirm its normal.cheers
Apr 22, 2009 | 2004 Volkswagen Golf
Brakes wont come up
sounds like a bad diaphragm in your brake booster. listen for air while running at booster , disconnect vacuum hose depress pedal if it is good there should be a big difference in pedal
Apr 13, 2009 | 1989 Mazda MX-6
Timing of Mastering and burning final copy to CD
I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
Hope this helps.
bd.
Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
App closed
take the phone and have it master reset or flash
May 30, 2008 | Nokia 3650
Master vs. repeater confusion
The master/repeater selection is for the purpose of determining which display is in control of the waypoint and route database.
Turn on both units and let them boot up. Do not answer the master/repeater question until both are on. Then press "Set as master" on the preferred one.
The units remember individually if they were set as a master or repeater the last time they were on. If they are powering up to find themselves in a different configuration than they were previously in, that will prompt the whole master/repeater thing to happen.
Sep 18, 2007 | Raymarine E120 GPS Receiver
14 people viewed this question
 Grubhead
Grubhead
