Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error:u043 The display says :"The following ink tank cannot be recognized" then it shows all of my ink tanks.  I just put in all new cartridges(Canon 8series cli-8c,cli-8m, cli-8y, cli-8bk, and Canon 5 series, pgi-5bk.  Can you help?
  • 2 more comments
  • logikal12 Sep 03, 2008
    I have a Canon MP800 and get an error code U043.
    When I install the large Black tank the light does not come on. I have installed 3 NEW Canon original tanks and it still does not work. It acts like it is not making a connection.
    How can I correct the problem.
  • Anonymous Sep 26, 2008
  • Luna C Nov 26, 2008
    I just installed Canon brand ink tanks and get the U043 Error message stating that the machine cannot recognize ANY of the tanks. I tried cleaning the chip on all----with no results.
    Any other suggestions?
  • Anonymous Mar 13, 2014
    PGI-9PBK tank is stuck - I am unable to get black on anything I try to print
Were is the chip located?is that the black thing that holds the ink cartridges
Posted on Apr 25, 2013
1st step: Press and hold the Stop/reset button for 5-10 sec then release. I
f ot working then use a Qtip and moisture (not wet) it with water. Cleans the chip gently and re-insert it back and redo the 1st step.
It work for me everytime!
Posted on Sep 05, 2008
Hello the following message comes up when i have put some new ink in. U043 the following ink tank cannot be recognised. any ideas? i have tried 2 ink tanks and same message comes up.
This Canon ink tanks has a memory chip.Try clean this chip with piece of cotton and some alcohol.Clean the contacts on the print head too.Sometimes happen this chip going to fail and printer not recognize it respectively not recognized and ink cartridge.In worst case your print head may be defective.
Oct 29, 2009 | Canon MP610 Photo All-In-One Printer
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
U043 (Applicable ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,454 people viewed this question
old marine
old marine
