Question about Dell 968 All-In-One Printer
Fax rings and picks up but does not print - Dell 968 All-In-One Printer
Trouble faxing using a USB cable to connect to network. Is it the USB cable, or do I need Ethernet?
First, fax only works over a phone line. Network is for printing and scanning, not fax.
USB is for connecting typically to a computer, not to a network...
May 06, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
Answ/fax do not work
Maybe it's not set to answer?
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Receive Mode
Make sure it's set to Fax mode.
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Ring To Answer
Pick the number of rings you want before the fax picks up.
Save and exit.
Apr 22, 2015 | Samsung C460FW Multifunction Printer...
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
THE FAX ANSWERS BEFORE THE ANSWERING MACHINE. ALL ALONG THE FAX WOULD ANSWER FAXES AND THE ANSWERING MACHINE WOULD ANSWER CALLS. NOW THE FAX ANSWERS ALL CALLS. ON FOUR RINGS. WHAT SETTINGS DO I HAVE TO SET...
You have to set the fax to at least one more ring than the answer machine. When the phone rings the fax wakes up and listens after the answer machine picks up, if it hears a fax it will take over and print the fax.
Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
Auto answer
first print out a help list this will tell you how to set the rings for the fax machine. it can be set up to ring on the six ring. try going into the receive menu and follow the prompts. good luck
Dec 25, 2008 | Brother IntelliFax-2820 Laser Fax
Fax problem
You will need to enable the "Distinctive Ring" feature on the PSC 2210 as shown here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 25, 2008 | HP PSC 2210xi All-In-One InkJet Printer
Won't receive fax
Reset RING DELAY so that machine picks up on 1st ring, and does not disconnect before fax can be sent to you.
Jan 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Dell 968 All-In-One Printer Logo
20 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
