Question about Rolleiflex 2.8 FX Medium Format Camera
Stuck diaphragm of Rolleiflex 3.5 F Medium Format Camera
Rolleiflex 3.5 F Medium Format Camera has stuck diaphragm, so how to fix it?
Rolleiflex sl35 mirror stuck in the open position and shutter won't release to send the mirror back down.
Try this: Give the shutter button a few quick, hard pokes with your finger. Don't be shy, you've got to give it a few good jabs. This can get the mirror unstuck. It's helped me before...
Mar 10, 2014 | Rollei Genuine Slr Sl35 Etc Front Body Cap
Volume buttons dont work
There are no volume buttons on a Linhof camera and it is not a medium format camera. If you have a Linhof problem you can call us at 800 735-4373 or Linhof service at 252 652-4401 if you are in the USA.
Aug 31, 2011 | Linhof 4x5 Master Technika 2000 Body -...
Just starting out with medium format. We bought a second hand Bronica SQ-A from a reputable dealer but the shutter will not **** in 'Normal' 'single exposure setting'. Cocks fine in Multi-exposure setting,...
Sounds like a problem with the single/multi "switch".
Film should not wind on in "multi" setting.
Back to the dealer - if he is reputable, he will get it fixed.
Dec 26, 2009 | Bronica SQ-A Medium Format Camera
What model Rolleiflex would have serial number T2163332?
Hello. Your camera is a Rolleiflex TLR model with a removable focusing hood. It was introduced in 1958, It has the famous Tessar lens, designed by Paul Rudolph in 1902 when he worked for Zeiss. It is Bay size I.
If you would like to download the entire data base you may. Here it is:
http://www.rolleirepairs.com/models.htm
Nov 18, 2009 | Cameras
I have a Rolleiflex 6006 medium format camera. Just below the lens is a cable release socket. When not in use, this socket is covered by a threaded screw-in cap. Unfortunately, I have misplaced the...
Try cutting down one of those foam earplugs, and stuff that in the hole, leaving enough to pull it back out when you need to use your shutter release. That will keep the threads clean, and they are extremely cheap and easy to carry around extras anytime it gets misplaced.
Oct 29, 2009 | Photography
Rolleiflex 3003 Battery Pack
where i can find the battery back, for 3003 the batteries can refield
May 28, 2009 | Rolleiflex 3001 35mm SLR Camera
Olympus is-50
It sounds like the rewind button on the bottom might be stuck. Refer to page 10 of the user guide and check it with a pencil tip to make sure its not stuck in the pressed position
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Shuter release button stuck
Caused by build up of dirt inside shutter release button :drip small amount of cleaning solvent like methilated spirits , isopropanol or benzine between the button and external wall using tweezers and then lift the button up and down by inserting tweezers into the inner cable release  thread .
If this does not work you will need to remove the front cover and clean more fully the release mechanism on the inside of the fron cover. 4 retaining screws are under the leather covering in the front ( 2 on top and two on the bottom )
Oct 11, 2007 | Rolleiflex 4.0 FW Medium Format Camera
Rolleiflex 2.8 FX Medium Format Camera Logo
Top Rollei Photography Experts
Tony
Are you a Rollei Photography Expert? Answer questions, earn points and help others
