Question about Royal Satellite 40 Typewriter
Need a knob
Kbnob came off has broken prongs
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Ac cord metal prongs broken
The "prongs" are part of the ac connector assembly. Your TV will require some disassembly to replace the part.
Jan 05, 2014 | Philips 50PL9126D/37B 50" DLP TV
Spring assembly in Coleman on demand hws
Hi Neil, I think I've sat down for several hours trying to work out how best to fit the spring in so it actually works.It's really difficult and I suppose the factory has a machine that does it and I think it's possibly the hardest thing on the whole unit to get right. I've looked at Youtube and there isn't a specific fix to this problem. Firstly,holding the knob in your hand, the spring sits in the knob with the smallest prong of the spring placed in a "V" shape mold which is thicker plastic than the other protusions. I've tried the other suggestions from forums to no avail, so where I'm at now is I know that the thick jutty out bit on the side wall that's got metal over it and the longest prong of the spring, both get positioned in between the two plastic fins on the other round part ( not the knob) on the machine. I drilled a small hole in the outside wall of the knob closish ( I sometimes use words you won't find in a dictionary but you get the gist) to that thick protusion with the metal on it. That's for a small screw driver to keep the longer spring prong close the thick bit on the side wall. Using a finger to push/ lever the long prong around then stick the screw driver in to keep it there.Problem is that when I do this , the small prong of the spring comes out. Maybe if I silicone the small prong in place and leave it for a day ,that might secure it for the time needed or rig up something to hold the short prong in place. I just think that if I can get to that stage , I'll be able put the knob on / screw in the screw and pull out the screw driver then tighten up the final turns of the screw. This method might sound unorthodox but if it works, problem solved with only a small hole left in the knob
Glenn from Australia
Dec 19, 2013 | Coleman Hot Water On Demand
Replacing the lever on a Pioneer DEH-P8400BH car stereo?
sorry no idea but suggest you contact Pioneer tech support
Oct 22, 2012 | Pioneer DEH-P8400BH CD receiver
Looking for a replacement knob
We have these in stock in black 15.00 includes shipping.
DickyO
Cleveland Business Machines
216-241-0027
Jul 15, 2010 | Royal Satellite 40 Typewriter
Control knob wont go on properly
Re-assemble the knob in the high range of the warm position, about 180 degrees from the "OFF" position. Install the long prong of the spring inwards (away from you as you look at the knob). That prong has to go in between the metal stop bar (again, about 180 degrees from "OFF") and a ridge on the inner knob. You should be able to reinstall everything while the spring is loose in this position. The only time you'll feel spring tension is if you rotate the knob counterclockwise towards "HOT". You won't feel any spring tension as you rotate the know clockwise back towards "OFF".
I figured it out after a fresh start in about 5 minutes.
Jul 05, 2010 | Coleman Hot Water On Demand
Adapter prong is broken on mmmmy wall outlet for my security camera. It broke when I tried to plug it into an extention cord. Only one of the prongs are broken.
You can try using an apoxy metal based resin to glue it back into place... or if you can access it properly solder the prong back in place...
If neither of these help - then I am afraid you need to replace your wall outlet
Oct 02, 2009 | Computers & Internet
Dog chewed power cord which includes power unit with circular control knob, I need cord and control unit assembly
If it is chewed before the control knob, just buy a 3 prong plug adapter and wire it up.
Sep 18, 2009 | Kitchen Appliances - Others
Charger prong is loose or broken and doesn't hold the charge
The charger prong is going to need to be replaced cause its not detecting your charger which is why its not charging.
An idea is to go on Ebay and look for a broken PSP where the prong is still good and maybe get one on the cheap and repair it yourself.
I did a quick search for you and here is the link:
http://shop.ebay.com/items/?_nkw=broken+psp&_sacat=0&_trksid=p3286.m270.l1313&_odkw=broken+pap&_osacat=0
You may get lucky or you can just get a new PSP but at least you have a few options or I just thought of you could look for a repair place and see what they would charge to replace it.
Jul 12, 2009 | Sony PlayStation Portable (PSP) Console
Menu knob
If you call the manufacturer, I'm sure they can get you any piece that you need, if you need a website or number, let us know
Mar 19, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Royal Satellite 40 Typewriter Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
