Question about HP PhotoSmart Office Equipment & Supplies
Cannot access registry hkey - PhotoSmart HP Office Equipment & Supplies
2 Suggested Answers
sekosan
  • 134 Answers
SOURCE: problems in setup softwaer on pc( registry) hkey
1st do a complete uninstall of the product if you have had i t before Then reboot Reinstall the scanner (don't connect your scanner until instructed)
Posted on Mar 01, 2011
How do i fix my registry
First defrag,then click on RUN,type regedit,go to hkey user, delete logs
Nov 11, 2014 | Computers & Internet
Problems in setup softwaer on pc( registry) hkey local machine .
Mar 01, 2011 | HP ScanJet 8270 Flatbed Scanner
How i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
My coby lptop getting tto slow....why...
Most PC Problems like Slow PC performance is because the Windows Registry is corrupted or has critical errors. Try using a Windows Registry Cleaner to cleanup all errors. An optimized registry ensures error free and fast computing experience. Read more at www.fixpcfreeze.com
May 06, 2010 | Coby NBPC1022XPBLK Netbook
Hauppauge ImpactVCB 166 make setting default to S-Video
it should just be a setting under options in the driver controll panle for the video card
the next way is probly above your technical abilities
if you care to try here is how
find the folder in programs files if not there check in the main c drive
once you find the driver folder for the video card you have to find the file that controls the settings
mostlikely ending in .ini
if your lucky it will be a simple text file that you can open with notepad
your going to have to do some research on what the proper wording is to make the setting defult to s-video
who know it might be just that simple
you could also try the registy approach and change the setting in the registry that says what the defualt is saposed to be this method is the fastest and esayest way it is also the proper way if the setting is unavalible from the video cards controll panle.
the hard part is finding the corect registry entry to edit or modify
to get into the registry
start/run/enter in the field "regedit" then click ok
the registry editor should now be open
be highly advised making mistakes in here can and will corupt your system to the point of not working at all
if you dont know what the hkey is for dont tinker with it you will be sorry if you do
export any key you plan on changing befor you change it thus if you do make a mistake you can simply double click the exported hkey to restore it back to its original state
note for some Hkeys this wont be a fix it because your system wont even boot after you corupt the Hkey
good lucky making the change you need to make and check the setting of the card driver first look for tabs and sub menues boxes that say advanced on them check thru those first
Feb 24, 2010 | Computers & Internet
I learned that my CA software was not operating properly because I still have Norton anti-virus on my system. CA support told me to uninstall Norton and reinstall CA. I downloaded the Norton removal tool...
Please delete the files of Symantec from hkey users, hkey local machines, hkey current user and remove Symantec, Norton files frm common files in program files application data, local settings... and next steps is .... to be continued..next week
Oct 18, 2009 | Symantec WinFax Pro for PC
Deleted Sonic DLA because of crashes and now computer won't recognize unformatted disc in drive
Go to the registry and delete the lower and "upperfilters"for the CD/DVD drive option. you can access it by going to this option. REGEDIT >> HKEY Local Machine >> System >> CurrentControlSet >> Control >> Class >> Select for the option which is the first {4D36.....}. After deleting the upper/lowerfilters, close the Registry Editor and restart the laptop. Then there try inserting a blank disc or any disc. Thank you.
Oct 07, 2009 | Dell Inspiron 6000 Notebook
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Instal problame
Try downloading the software and installing it. Make sure that you download for the version of windows that you have.
http://h10025.www1.hp.com/ewfrf/wc/product?product=441115&lc=en&cc=us&dlc=en&submit.y=6&submit.x=2〈=en&cc=us
Dec 30, 2008 | HP PSC1410 Printer
Software problem
registry mechanic is a fluke program.
Don not trust it. Suggest you use Mcafee or another popular anti-virus solution.
What are you trying to fix ?
Jul 03, 2008 | Computers & Internet
11 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
